Just Died
Old Jun 23, 2009 | 06:41 PM
Lumpy's Avatar
Just Died
Alright, I was driving home this evening and she just quit (92 Pickup, speck in sig). I have a new fuel filter, good air filter, new cap & rotor with plugs, and 1/2 tank gas. I know I have a bad knock sensor, throwing codes. So I was heading home and just quit...nothing. All electric works, starter runs and it has spark, will hit like 3 times and die. Am I looking at a fuel pump? Will this throw a code as well. She is sitting a few miles from home now, Will know more tomorrow evening when I can get to her. Any ideas will be helpful.
Old Jun 23, 2009 | 06:46 PM
iamsuperbleeder's Avatar
hmmmm, could be fuel pump yes, but I would start by narrowing down what's NOT happening in the engine bay that needs to happen for the engine to run; check for spark first (could be pickup in the dizzy, coil, ignitor, etc), then fuel (could be pump, regulator, wiring circut, etc.), and go from there
worst it could be is the ECU
keep us posted!
Ardent's Avatar
Test the fuel pump by loosening the cold start fuel line, and turn the key to the on position. If the Fuel pump is pumping, gas should be leaking from that spot.
Old Jun 23, 2009 | 06:48 PM
Tubbyfatty's Avatar
efi fuse?
I only say that because there was a thread from yesterday about some dudes 4runner that just died.
https://www.yotatech.com/forums/f116...agnose-184933/
post 18 he says EFI fuse.
Old Jun 23, 2009 | 07:13 PM
Lumpy's Avatar
keep us posted!
Will check spark first...come tomorrow evening after work.
but seems like spark is there, she will hit 2 or 3 times while cranking then nothing. Let her sit for 30 sec and go again and the same thing. really strange!!!!
Cold start valve will be test 2...easy she'll be cold then and easy to test.
Originally Posted by Tubbyfatty
efi fuse?
If it was the EFI fuse would it try to start, hit 2 or 3 times??? Could it hit on residual gas???
Old Jun 23, 2009 | 08:21 PM
Stuwy123's Avatar
Jumper the diagnostic to get your CEL codes.
Tell us what you have for codes.
That would be some help.
Old Jun 24, 2009 | 04:54 AM
Lumpy's Avatar
I will this evening...it was 10:00 when she quit and I was wanting to get home. Had a few and didn't need the trouble (3 drinks puts you over the limit) Didn't have a light or a paperclip with me ether, other wise I would have ran the codes...
I was thinking...I have not fueled up for a bit...maybe the fuel gauge quit working just maybe it's hung up on something. I'm going to try dumping some gas in it.
It has all the symptoms of no gas except for the gauge reading 1/2 tank. I'm hoping...
Old Jun 24, 2009 | 05:17 AM
nv4runner's Avatar
Don't forget to check for air. I've heard many stories of things getting sucked into and blocking the filter, or even going past the filter because it was damaged.
Old Jun 24, 2009 | 02:50 PM
Lumpy's Avatar
OK this is what I have now...Dumped gas in and yes the needle moved so it wasn't out. All fuses seem to be alright. I have spark it's not getting fuel. I did check the "Cold Start Valve" and nothing came out. So I put some gas in the intake, I have an aftermarket intake with a small hose on it. So I poured a little in and she fired up and ran for about 10 seconds, until the gas ran out...
So now I need to find why the pump is not turning on or is the pump shot?
How do I test to see if the pump is good? Are there just a few wires I can jump?
Do I have to drop the tank to do this?
Old Jun 24, 2009 | 06:09 PM
just a 22re's Avatar
to test the pump have some one sit inside and ear for the pump to turn on when they turn the key over it should hum or something and you should hear it if not then it could be the pump
Old Jun 24, 2009 | 06:43 PM
Lumpy's Avatar
I have never been able to hear the pump, unless you can't hear it in the cab...as of now I know the pump is not running. I need to know why??? Time for reading, tracing wires and I guess I gotta drop the tank.
Old Jun 25, 2009 | 04:43 AM
Lumpy's Avatar
Anyone...Are there 2 wires under the hood that I can jump to test?
How about relays? Am I missing something?
I really do not want to drop the tank if I don't have to...
I'm looking for a FSM now.
Old Jun 25, 2009 | 04:44 AM
abecedarian's Avatar
How long you been here?
Open the diagnostic connector and jumper the Fp and +B terminals.
Old Jun 25, 2009 | 04:49 AM
As for relays, the Circuit Opening Relay controls the fuel pump. It gets 2 signals, either one of which should actuate the fuel pump.
-1: turn the key and crank the engine closes the COR and the pump should run.
-2: engine is running therefore a contact in the air-flow meter (on top of the air filter) causes the COR to close and actuate the fuel pump.
Old Jun 25, 2009 | 05:02 AM
Lumpy's Avatar
I know I know...Ok here is another one...What do the Fp and +B terminals do? Which ones are they? This is all I have to go on right now...Mine looks like the top one.
Old Jun 25, 2009 | 05:08 AM
Fp is "Fuel pump" and +B is "positive battery". Jumpering them connects the fuel pump to the battery (when the key is on).
Your truck's connector should have a lid on it and on the underside of the lid is a diagram showing the labels assigned to the terminals.
Similar to this:
Old Jun 25, 2009 | 05:13 AM
Lumpy's Avatar
Similar to this:
Sweet!!! I have the lid but I don't have the nice little diagram.
Thank you!!!
Old Jun 25, 2009 | 05:25 PM
Lumpy's Avatar
Alright, I did the jumped the terminal in the Diag box and still nada...Going to get a fuel pump within the week and hope to have it installed. Next weekend.
Thanks for all your help and I'll keep ya posted...
Old Jun 25, 2009 | 06:15 PM
Matt16's Avatar
So did Michael
Old Jun 26, 2009 | 05:31 AM
Lumpy's Avatar
But mine will be coming back to run again!!!
Just ordered a pump should have it here in a few days. Ebay...
