Transmission interchange
Old Jun 16, 2009 | 11:29 AM
phranticness's Avatar
I'm working with a 91 4X4 4 cylinder 5 speed. needs a transmission. It's a W trans
I have a couple 5 speeds from 90 - 95 4 runners that were 6 cylinder - manuals.
Can I run the 6 cyl trans in the 4 cyl truck, swap bell housings and transfer cases?
1. are they a direct bolt in?
2. are the gear ratios different, if so by how much.
Thanks in advance.
Old Jun 16, 2009 | 11:41 AM
dropzone's Avatar
Fossilized
Try reading Here and this one
Old Jun 16, 2009 | 02:20 PM
MudHippy's Avatar
Thanks in advance.
I believe you can swap bell housings. Not so for transfer cases(different spline count on transmission output shaft). So, you may be able to use the 6 cyl combo together, but it might also require relocating the transfer case crossmember. Shifters might not be in the right place either.
1. Nope, obviously.
2. Yep, see HERE for gearing ratios of W and R(6 cyl) transmissions.
Yer welcome!
Old Jun 17, 2009 | 11:00 AM
Thank you!, more trouble than it's worth for this customer, the correct used and rebuilt trannys are plentyful enough, fabbin isn't nessicary.
I really appreciate it!, I can't remember what i used to do before the internet/forums - oh ya, work a lot harder.
Old Jun 17, 2009 | 01:59 PM
MudHippy's Avatar
No problem, and wise decision I might add.
Oh...and I forgot about the driveshaft incapatibility too. 4 cyl shafts no bolt to 6 cyl transfer cases most of the time(different bolt hole patterns). Not to mention the shaft lengths not being equal. An extra big headache enlargement (or hole in pocket) for those who dare try.
ToyotaMD
Sep 22, 2015 06:28 AM
briholt
Sep 20, 2015 10:26 PM
TransAmBandit
Sep 20, 2015 06:08 PM
icentropy
Sep 10, 2015 05:03 AM
kelly1450
Sep 2, 2015 12:29 PM
