How do I stop chain guard leak
Old Jun 20, 2009 | 06:46 AM
Outsane's Avatar
Put in new timing chain, water pump, oil pump.
Used grey sealant on every thing, evenness the bolt through the head.
And the damn thing is still marking it's territory every where I go.
Any suggestions?
Old Jun 20, 2009 | 06:48 AM
algranger's Avatar
Where exactly is it leaking from? Between the head and the timing cover?
Try using Right Stuff gasket maker, its a little spendy but i dont even use gaskets anymore i just make them with it
Old Jun 20, 2009 | 10:31 AM
Outsane's Avatar
yup between the head and the chain cover..
Any suggestions that do not include taking the front end apart?
Old Jun 20, 2009 | 11:51 AM
TORTIS's Avatar
did you pull the head or the oil pan? I have never been able to replace the t chain without pulling one or the other.
Old Jun 20, 2009 | 12:51 PM
algranger's Avatar
I'm assuming you left the head on to replace the chain, the head gasket doesnt like to reseat, i would take the cover back off and pump a bunch of gasket maker between the head and the cover, get back in the corners and everything.
Old Jun 21, 2009 | 06:15 AM
Outsane's Avatar
I did not pull the head or oil pan.
Crap I really did not want to pull the cover off
Old Jun 21, 2009 | 10:12 AM
TORTIS's Avatar
I feel your pain. Been there, and done that.
Old Jun 21, 2009 | 01:06 PM
algranger's Avatar
Well if do a half ass job, your going to get half ass results. Now your looking at undertaking the whole thing again.
Do it once and do it right
Old Jun 21, 2009 | 01:58 PM
Outsane's Avatar
I didn't do a half ass job the first time. I used sealant on all the edges the first time, that's why I am surprised it's leaking.
Old Jun 21, 2009 | 02:05 PM
Team420's Avatar
so does this mean it was a "whole" assed job j/k
Old Jun 21, 2009 | 02:58 PM
Teuf's Avatar
clean r up re-goo
Old Jun 21, 2009 | 03:05 PM
Junkers88's Avatar
That's a lot better than a "holed ass" job. I heard of those...... something to do with salad.
Old Jun 21, 2009 | 04:29 PM
abecedarian's Avatar
If you didn't pull the head or oil pan, you set yourself up for leaks. The timing cover is compressed between the head and oil pan, but is more 'closely' connected to the head. The 'factory' method for servicing anything within the timing cover requires pulling the head, if that helps. Alternately, you can pull the timing cover by dropping the oil pan... but you said you didn't do either so... no wonder you have a leak.
Don't use any type of RTV sealant. Spend some time and money, and use Hylomar.
Unfortunately, you'll have to take it all apart (either head or oil pan) to fix it.
Old Jun 21, 2009 | 05:13 PM
Outsane's Avatar
Damn I was hoping for a magic fix
Old Jun 21, 2009 | 05:22 PM
So did everyone who voted for Obama... too bad they're all being let down.
Anyhow, if it's leaking up by the head, you'll have to pull the timing cover, at least, to fix it.
Old Jun 21, 2009 | 06:39 PM
Outsane's Avatar
sweet!
Old Jun 21, 2009 | 07:00 PM
you've already ruled out the semi-circular plugs and the rest of the valve cover, right?
Old Jun 21, 2009 | 08:44 PM
Outsane's Avatar
Yeah the leak is below that
Old Jun 21, 2009 | 10:56 PM
874runnersr5's Avatar
yeah, i was debating leaving my oil pan on.. im glad i did take it off. it made seating the cover alot easier and i got to play with chunks of plastic in my oilpan
Eggslinger
Jun 8, 2019 03:32 PM
thefishguy77
Jul 30, 2015 10:59 AM
Jonny246
Jul 12, 2015 04:51 AM
cars-guy
Jul 11, 2015 07:51 PM
icentropy
Jul 11, 2015 07:21 AM
