- 91 lags power
- 88 Pickup Randomly next morning wont start
- '94 3vze crankshaft timing gear play?
- 22r holley
- opinions on the ITM engine rebuild kit for the 3vze
- flashing red interior light and no start on truck.
- g54 power capacity
- Hand turned compression test
- are thorley 22re try-y headers universal fit for other year trucks
- My truck just got totaled....
- rear spring replacement
- 1994 4runner need help passing smog
- Distrbutor wiring... need help asap
- CV Axle popping out
- Oil cooler lines to drain block?
- 95 3vze oil leaking half moons?
- '87 4Runner Stumble!
- Best way to swap out interior / remove smells?
- snow driving question
- Valve damage from turning crankshaft
- Need advice on IFS set up!
- Shifter Boot HELP?!?!?!?
- some mods and questions on the plate for winter
- knock knock
- 4WD Not Working (1990 4Runner)
- TCR Performance in Arizona 3.0 Long Block?
- electric motor question
- 22re, on start fast idle only ,then surges up and down
- code 42 and 43
- High octane gas
- Soft Top people I need your opinions
- Just bought a 95 4Runner 22-RE, some questions
- Swapping a 3.0
- Fuel Sender Nichrome Wire Diameter. Rebuild.
- 3vze cooling issues....
- 3.0 engine replacement advice
- can any one tell me whats the name of this plug?
- ? rust HOLES repair, cab
- weird noise need help
- propane 22re
- Front Wheel bearing issues
- A couple of oil related issues
- Total Chaos GEN2 Caddy KIt for 86 Pickup Question
- Rebuild, new fuel injectors
- New Member+New Pickup+Seized Engine=Mod Time!
- 22re 3.0 Trouble Shooter
- 88 4runner won't Start what is this wire HELP !
- Anybody have any experience with Calif BAR Smog Referee??
- Oil leak between head and block. 22re.
- Flashing 4wd light on 91 pickup
- Possible blown HG, head shave required?
- Interestin squealing noise from transfer case
- overheating when the heater is on
- Phantom Engine Power issue
- Cold start problem??
- Running rough, wont rev?
- 22RE, best replacement motors?
- 7.5" rear end???
- High idle at cold start
- vibration coming from rear driveshaft?
- Wont start when freezing
- 1993 22re VAF meter cold+moisture problems
- Odd issues
- Hard start when cold outside
- 22R Electrical Issues (maybe?)
- blown 22re/22rte swap
- Spring on tailgate regulator
- My new Trail Gear rear bumper
- Low Idle issue
- Single pcv valve
- 1991 4Runner 5spd/v6 4WD not working up front, Rear Aussie not engaging
- Coolant temp sensors 3vze
- Brake Master Cylinder Leak
- What sensor is this????
- Does this seem like a head gasket to you?
- Transmission stuck in or out of gear
- Finally got some new tires and wheels!
- Electrical problem after replacing trans??
- What water pump to buy?
- Will low oil pressure be the end of my truck?
- stalls easily and runs poorly when hot
- Transmission swap
- Piston Ring Installation HELP
- 94 Pickup NO POWER
- Low Idle Issues 22re - Adjusted idle/TPS still stays at 500 RPM
- Newbie with an AC fan issue
- what cam are you running in your 22re?
- fj80 coil for 95 4runner
- Filter relocator installed ! With pics !!!
- transmission oil dip stick from a 89.
- Buzzing noise from transmission
- High idle and overflowing antifreeze?
- PCV grommet fell into Valve cover.
- Can I put an 87 or 88 22r (carb) in an 87 4runner 22RE
- Pic Request: egr Passage way in a 22re head
- Oil Seal question
- Fluid in rear brake drum
- what do these plugs go to on my 22re?
- extreme high Idle on cold start
- Pulls with hubs locked
- timming chain gide broke while driving! i think
- older model big O head lights on a 89
- RTV Silicone question
- 22RE - Fuel Pump
- Learning to live with a front locker
- blowing ignition fuse on 86'
- Will these Tundra wheels fit my 89 Pickup?
- '91 3.0 idle issues
- Water pump question
- 3VZE coolant temp sensor control gauge?
- steering parts on Ebay
- Timing is off?!
- Internal knocking on 22re motor
- Remote start - Heater & controls do not when remote started?
- Fuel Pump not kicking on and EFI fuse blowing
- Where can I find a Factory Alarm/Keyless Entry Remote
- 3/8" or 7/16" Bolts for Body Lift?
- first gen 4runner passenger seat
- my new toy needs love
- Tutorial on heater core? Searched, no luck...
- Cab lights on a 1st gen 4runner
- Burning Coolant Fast
- Surging Idle 1990 22re pu: need suggestions
- 91 3.0 Coolant sensors
- Need help with Turn signals
- Need vacuum line help 86 22RE
- Power steering box question for a newbie
- frozen cam bolt
- gas spraying from intake chamber
- Vibration in 2 Hi,hubs locked??
- parking brake question
- how to know if the central carrier bearing is shot.
- Torque Converter install
- 92-95 4runner Bumper with a 92-95 Pickup Grill?
- engine heats but heater core does not
- rear hatch wont open
- 22re plugs below intake manifold pass side?
- My '90 SR5
- stripped a head bolt!! Help?
- Strange clutch issue
- 88 Pickup clunk in 4wd
- Runner Engine surging while driving
- Fake weber 32/36?
- abs light on
- clutch wont engage
- coolant level keeps dropping
- source of oil leak, help
- 1986 4runner wont go over 55mph...help
- 88 4Runner V6 brake master cylinder
- Leaky rear cam plugs 3vz
- temp guage spikes before truck is started
- Offical Cost of Daily Driver Resto
- Choke opener
- Plastic Screw Inserts for Dash, etc.
- A service engine soon light problem I can't figure out on a 93' pickup
- High unstable Idle since Cold temps set in
- speedo cable squeek?
- Interior Restoration Question
- idle drops and dies when put in gear while cold
- 4wd massive rattle
- Name this Part of the Cooling System
- Truck dies when giving it gas IN GEAR.
- high idel
- 88' 4Runner loses power when it rains?
- u-joints
- replacing camshaft need help
- Conditioning Vacuum Diaphragm?
- For the love of pete; PLEASE READ THE FAQs FIRST!
- Freeze 12 recharge
- Clutch / shifting problems
- 32x11.5x15 on stock rims
- 22re Engine Problem
- The Deal of the Century!
- High Beams shut lights off...
- 1994 3.0 L V6 4runner NO torque, No power
- Straight plenum/throttle bore swap
- Headlights/Dash lights no longer working - Relay locations?
- LOUD creaking from front end when in 4WD - tight turns
- 91 4 runner battery diagram request
- new exhaust tomorrow need some opinions
- 4wd pop
- Front Coils
- getting ready for the lift install,but!!
- SAS Dual-Case Front Driveshaft Problem (?)
- a/c dropping engine rpm's solved
- DT header gasket advice ?'s
- Installing Crossover pipe
- Rear oil seal on transfer case
- 22R engine heater?
- 22RE Idle Surging Fixed.
- 22RTE Turbo Side Pictures
- 87 4Runner - 22re Starter
- 92 4 runner idle too low....HELP!!
- Catalytic converter flow direction?
- 88 4runner AC recharge
- fix oil leak, wait, or full rebuild
- exhaust manifold glowing
- Bracket lift info
- Power Windows 87 Runner....
- Small coolant leak with pics
- need help with new front clip!!!
- Drivers side window gets power, but doesn't move
- 90 pickup 22RE No Start Condition
- My 2inch ToyTec Lift Thread
- Bosch TPS
- 88 runner 3vze loud knock...
- truck wont turn over need help (wiring)
- 87 4runner Vacuum Lines
- Electrical issue with display and starting?
- 22re vs 3.0 v6 need help on rebuilding
- got the softopper!
- Anyone use a OE Replacement Radiator shroud ?
- Shifter info
- Driveline splined shaft
- 22r idles but dies when i give it gas
- 4runner, rear side windows dismantle
- 3vz Drive Belt & Pully Pic Request
- 2.4 turbo on hilux 2.8
- Loud shuttering noise from transmission after installing Zuk coils?
- my runner hit a tree, need advice/measurements
- 90 3vze hesitation/miss :(
- SR5 cigarette lighter wiring?
- '86 interior fuse box removal
- Idler arm affect on toe setting?
- oil in coolant/ not coolant in oil -
- no start... ahh
- T3 upgrade
- 2WD on 33's build plan, any advice?
- using a non Toyota drive shaft?
- 89 4x4 p/u electrical isssues headlights runs rough..
- Truck vibrates in 4 High..
- 22RE Starts and Dies
- Battery Cables '95 3VZE
- Wierd cooling problem in 3 VZE
- Proper way to perform radiator flush
- Show off your swapped in seats!
- O/D flashing all codes 61,62,63, and 64
- 92 4Runner coolant leak
- rear tire rub on frame!! 2nd gen 4runner
- Driving RPMs Too High ?
- I cant get my tail lights and license plate lights to work!
- 2nd gen non-US diesel - they have a hood scoop?
- What to grab from a couple of 84/85 trucks?
- Another EGR question
- Starter problem....
- Mechanic didn't sound optimistic
- Starting Problem (yes i searched first)
- Centerlink, pitman allignment issue
- 22re intake manifold bolts problem
- High idle does not kick down
