headgasket gone!!!!!!!!
Old Nov 16, 2010 | 10:38 AM
8yota6's Avatar
well i decided to go ahead and start tearing the 22r apart after all of the overheating and smokin issues. I got the head off today and it looks like the head gasket is done with. antifreeze sitting in the cylinders is not a good sign i assume. pistons have alot off carbon built up on the top of them also. i will post some pics later.
Old Nov 16, 2010 | 11:26 AM
xxxtreme22r's Avatar
FYI when you pull off the head you will get some left over coolant in the cyl's.
Old Nov 16, 2010 | 12:46 PM
8yota6's Avatar
so does that mean the gasket may have not been blown?
Old Nov 16, 2010 | 12:47 PM
Depends on how much coolant was in the cyl. and how well it was drained before hand. I think I had maybe less than a half inch of coolant in mine when I pulled my head.
Old Nov 16, 2010 | 01:31 PM
8yota6's Avatar
Old Nov 16, 2010 | 01:35 PM
well, you were definitely burning some oil there.
Old Nov 16, 2010 | 01:40 PM
8yota6's Avatar
would a bad headgasket cause the oil burn
Old Nov 16, 2010 | 01:42 PM
it can as well as bad rings.
Old Nov 16, 2010 | 01:47 PM
8yota6's Avatar
so from the looks of the pics would you recommend a complete rebuild?
Old Nov 16, 2010 | 01:51 PM
how many miles were on it? Did you happen to do a compression check before you tore it apart?
Old Nov 16, 2010 | 02:04 PM
8yota6's Avatar
about 180000. tried to do a compression test wasnt for sure if i iwas doin right tested three cylinders and i think i got like 158 120 120
Old Nov 16, 2010 | 02:09 PM
Elton's Avatar
eww fram filter
Old Nov 16, 2010 | 02:12 PM
if that's accurate, time for a rebuild. maybe even a valve job and or new head.
Old Nov 16, 2010 | 02:13 PM
Outsane's Avatar
all the motors with hg issues I have seen have had nice steam cleaned pistons, and valves..
Old Nov 16, 2010 | 02:14 PM
fyi head gaskets also fail between the oil passages and cyl walls. although somewhat uncommon.
Old Nov 16, 2010 | 02:20 PM
Outsane's Avatar
good to know..
Old Nov 16, 2010 | 02:26 PM
yeah and a real bugger to diagnose too. lol.
Old Nov 16, 2010 | 08:12 PM
muddpigg's Avatar
need to hose the mud out from time to time. It insulates the engine and you have mud caked into your radiator with restricts cooling. Not a good combo.
Old Nov 16, 2010 | 08:16 PM
PismoJoe's Avatar
Looks to me like #4 was getting a little bit of coolant, maybe early stages of HG failure. Xtreme is right, most oil burning issues are from the valve stem seals.
Hope to see some more pics of the build!
TheBFA
Feb 15, 2020 06:55 AM
alimant100
Jan 20, 2016 05:58 PM
_Nicco_
Sep 21, 2015 03:06 PM
defrag4
Jul 31, 2015 10:50 AM
toofly1999
Jul 25, 2015 07:09 PM
