Heater Hose Hardline Help
Old Nov 16, 2010 | 07:55 PM
DWEINBERG01's Avatar
So today while trying to remove my coolant lines next to the firewall, I proceeded to pinch the hardline running into the passenger side firewall completly shut. After several minutes of , I was able to open it up a bit on the end.
Does anyone know how difficult it is to change out that copper line and are there any special tricks to it.... or is there a way to open it back up without destroying it. Any help is appreciated.
Old Nov 16, 2010 | 07:57 PM
PismoJoe's Avatar
You could always cut off the bent part of the tube, and run a longer rubber heater hose to the fresh part you just cut off. Then you wouldn't have to go junkyarding and replace the hardlines
Old Nov 16, 2010 | 07:59 PM
muddpigg's Avatar
can you cut the smushed piece and put a stint of hose to replace it with a clamp each side of the splice.
Old Nov 16, 2010 | 08:00 PM
PismoJoe's Avatar
is there an echo in here??
Old Nov 17, 2010 | 12:51 AM
TNRabbit's Avatar
Are you talking about the short piece protruding from the firewall? Damn, I'm glad I'm not you~
Old Nov 17, 2010 | 04:32 AM
xxxtreme22r's Avatar
isn't that short piece (well two) protruding from the firewall the actual heater core itself?
Old Nov 17, 2010 | 08:27 AM
TNRabbit's Avatar
I'm pretty sure that's what he's talking about. That's why I said I'm glad I'm not him~
The heater core is a PITA because you have to disassemble the entire dash~
Old Nov 17, 2010 | 09:26 AM
RustBucket's Avatar
bend it back into a circle with a screw drive or awl, JB weld any cracks, and seal the heater hose into it with a crap load of Permatex #2. It just might work!
Or bypass the heater if you don't want to mess with it.
Old Nov 17, 2010 | 03:33 PM
swampfox's Avatar
I used a pair of needle nose pliers to straighten them out on an 86 . Put the tip of the pliers inside the pipe and open them just keep rotating and opening untill you get the shape back.
Old Nov 18, 2010 | 04:49 PM
Problem solved. I took a harbor freight brass drift (cone shaped) stuck it in the end and used to a 3lb sledge to "massage" it in. Got the tube back to some semblance of a circle. Thanks for all your help.
gyroscope7
7
Sep 27, 2015 08:39 PM
Hugh_Mann
Sep 16, 2015 03:59 AM
LotOMiles
Sep 14, 2015 11:45 PM
--Oz--
Sep 6, 2015 01:06 AM
128keaton
Sep 3, 2015 05:09 PM
