Surging Idle 1990 22re pu: need suggestions
Old Nov 24, 2010 | 06:01 PM
blueyoda's Avatar
I am about to give up on me friends 1990 22re pu. We have tried almost everything mentiond on yotatech to fix the surging idle. It seems to be getting worse and we are about to light a fire
Old Nov 24, 2010 | 08:11 PM
myyota's Avatar
It would help if you told us what you have already done ?. What i would recommend is that you check the TPS for proper adjustment, check the idle, if its set to high it will cause surging, also check for vacuum leaks.
Old Nov 25, 2010 | 02:50 AM
92 TOY's Avatar
coolant level, coolant loss, bad sensor can also lead to loping idle.
Old Nov 25, 2010 | 04:03 AM
jeepwilson's Avatar
Yes what have you done so far?There are a lot of things that can lead to this problem.
Old Nov 25, 2010 | 08:04 AM
blueyoda's Avatar
sorry
Changed/tested
TPS
Enitre TB
egr
thermostate
vacuum lines
fuel filter
air filter
PVC
lines going to iavc
Thanks
Old Nov 25, 2010 | 09:32 AM
mightymouse's Avatar
look here. https://www.yotatech.com/forums/f116...ensive-199356/
Old Nov 25, 2010 | 11:30 AM
92 TOY's Avatar
Originally Posted by mightymouse
Old Nov 26, 2010 | 01:35 PM
tysen86's Avatar
Check all your grounds too. mine had a bad ground going to the engine block and it caused a crazy idle.
Old Nov 26, 2010 | 03:30 PM
1990yota-pickup's Avatar
just drive it until it wont drive no more than fix it... it sounds like a cam problem to me..
Old Nov 26, 2010 | 06:34 PM
jeepwilson's Avatar
What about unplugging the mass air flow sensor while running and see if it changes.Mine went bad on a 22RE and it started running rough and very rich.If not that maybe another computer.If all sensors are good maybe it is the brain thats talking to the sensors!
Old Nov 27, 2010 | 05:48 AM
its always worth a shot...
Old Nov 27, 2010 | 02:36 PM
muddpigg's Avatar
Originally Posted by razed
ungplugging the air flow meter will cause the fuel pump to not run.
defeats the purpose, no?
but the idle surge will stop. LOL.
Old Nov 28, 2010 | 09:42 AM
blueyoda's Avatar
forgot to mention we changed the MAF also
Old Nov 30, 2010 | 09:33 AM
DIYFLATTY's Avatar
HEY GUYS, I FINALLY REGISTERED AS A MEMBER. BLUEYODA HAS BEEN DOING MY POSTS SO FAR. I HAVE TRIED EVERYTHING THAT EVERYONE HAS MENTIONED, EXCEPT CHANGING THE COMPUTER. ALL HELP HAS BEEN GREATLY APPRECIATED, BUT TO NO AVAIL. THE ONLY TIME THE SURGING GOES AWAY IS ON A WARM DAY LEADING ME TO BELIEVE THAT PERHAPS THE VALVES MIGHT NEED TO BE DONE AS THEY COULD BE AFFECTING PRESSURE IN THE HEAD GOING TO THE TB. REALLY AT THIS POINT I'M GRASPING AT STRAWS.
I HAVE TWO SPARE PARTS VEHICLES SO ANYTHING AND EVERYTHING CAN BE CHANGED
IF ANYONE HAS ANYTHING ELSE THAT MAY BE HELPFUL PLEASE POST UP. THANKS AGAIN!
Changed/tested
TPS
Enitre TB
egr
thermostate
vacuum lines
fuel filter
air filter
PVC
lines going to iavc
MAF
Old Dec 1, 2010 | 05:58 AM
DIYFLATTY's Avatar
Yes razed i blocked the line to the brake booster it didn't make a difference.
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
kyletbert
Jul 17, 2015 11:39 AM
ptb12
Jul 5, 2015 01:49 PM
