stalls easily and runs poorly when hot
Old Nov 27, 2010 | 10:35 PM
Bigyota1989's Avatar
so i have this weird problem with my yota as of lately. when i start it when its hot..it wants to stall so i have to rev the gas a couple times and itll smooth out..then if i start going..itll bog down and even some times skip and it has barely any power going up hills. the wiers part though is sometimes itll clear out..i cant really pinpoint this so any suggestions would be appreciated thanks!
Old Nov 30, 2010 | 06:10 PM
Anyone?
Old Nov 30, 2010 | 08:17 PM
BajaRunner's Avatar
Welcome to the club!
For you though, I'd check your ECT sensor, cold start injector, cold start injector switch, and make sure your idle air control valve is working properly.
22re I assume!?
FSM
http://ncttora.com/fsm/index.html
Old Dec 6, 2010 | 11:04 PM
ChzSoda's Avatar
Same problem with my 3vze. Subscribing.
Old Dec 7, 2010 | 01:51 PM
well..mine stopped running completely now....
Old Dec 7, 2010 | 03:57 PM
rworegon's Avatar
I'd check the coolant, oil, and spark plugs too for anything unusual. Was it running and then died? Or will it not re-start after being turned off?
Old Dec 7, 2010 | 06:50 PM
wont restart after being turned off..im thinking fuel pump
Old Dec 8, 2010 | 11:23 AM
ChzSoda's Avatar
I have to crank mine for about 2-3x as long as I should, while giving it a shload at the pedal. Was that how yours was before it quit on you?
Old Dec 9, 2010 | 04:18 PM
nahh man thats weird...but my problem was the cold start time switch and cold start injector and the computer needed to be reprogrammed
Charecter1
Nov 6, 2023 10:08 AM
Sleaker
Aug 26, 2020 06:03 AM
Poncho0206
Jul 10, 2015 06:21 PM
crashburnoveride
Jul 10, 2015 06:39 AM
Jnkml
Jul 6, 2015 01:20 PM
