High Beams shut lights off...
Old Nov 22, 2010 | 06:09 AM
quiggs12's Avatar
I have an 88 Pickup (22RE) and a few days ago all of my lights worked fine. The truck has a Fisher Speedcast plow on it and when the plow lights are turned on the truck lights shut off (as intended). However, now when I turn the truck lights on the High Beams shut the lights off. When the plow lights are on High Beam is actually low beam and low beam is High??? My rear driver's side blinker makes the back lights flicker when it is on. The passenger side seems fine though? Thoughts on what this could be and where to locate the actual issue would be greatly appreciated! Thanks
Old Nov 22, 2010 | 06:17 AM
xxxtreme22r's Avatar
FYI when you turn your high beams on your low beams would normally go out, sounds like just your high beams are not working, check you fuses under you hood. Do you hear the relay come on when activating your high beams?
Old Nov 22, 2010 | 06:26 AM
rattlewagon's Avatar
Check your grounds!
Old Nov 22, 2010 | 06:28 AM
88toyblackjack's Avatar
It also could be the multi function switch in the column. The contacts get dirty, or sometimes burn out. This is the switch that has the lights, cruise, blinlers and windshield wiper control. Its under the steering wheel, but not too hard to change out
Old Nov 22, 2010 | 08:39 AM
quiggs12's Avatar
Where specifically are the ground(s) for the headlights?
Old Nov 22, 2010 | 08:42 AM
the grounds for the headlights route back to the relay's. when the lights go on what you are doing is grounding out the lights themselves. Toyota uses switched grounds at the headlights using a common 12V supply.
so basically there are two grounds but it's your regular wiring back to the relays and fuses in the fuse panel. These grounds are not "normal" chassis grounds.
Charecter1
Nov 6, 2023 10:08 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
ZONAYODA
Jul 13, 2015 07:17 PM
