4wd pop
Old Nov 21, 2010 | 01:53 PM
The Rockin Hoskin's Avatar
Unhappy 4wd pop
Hey, I drive an 89 with manual hubs. A friend and I did a break job a few months ago and used marine grease instead of bearing grease. The first time I locked the hubs in the driver side hub started popping in 4wd and out. When I unlocked the hubs it stopped. So we took the hubs apart and changed the marine grease out with hi-temp Red grease. It worked for a wile then one day when I was drivin down a loggin road the hubs started popping again. Do you have any idea what the sound may be, how to fix it and if or what I souhld replace.
Old Nov 21, 2010 | 02:34 PM
muddpigg's Avatar
Inspect it for damage: hub body, hub gear, and shaft splines. Also the CV joint side of the half shaft.
I8URSVT
Apr 17, 2016 03:38 AM
Daenerysdad
Oct 1, 2015 07:33 PM
kawazx636
Sep 29, 2015 08:22 AM
Anthony Lee Mathis
Sep 15, 2015 07:22 AM
May-39
Sep 6, 2015 01:05 PM
