exhaust manifold glowing
Old Nov 20, 2010 | 02:38 PM
Dennis140's Avatar
First of all its a 95 4runner 3vze limited paid 500 bucks been sitting up three years got it running but manifolds glow thinking cat or injectors clogged any helps is appreciated greatly
Old Nov 20, 2010 | 02:41 PM
93YotaMonster's Avatar
sounds like its running lean, or the cat.
Old Nov 20, 2010 | 02:43 PM
yeah it could be a clogged injector or a bad one.
Old Nov 20, 2010 | 05:30 PM
UKrunner's Avatar
Injector would have to be stuck open, not clogged. You are burning fuel in the manifold. Check timing and plug wires, and by that I mean check to see if each wire is connected in the right spot at the distributor and each wire is going to the correct plug. Cat may be plugged or partially plugged.
Old Nov 21, 2010 | 12:21 PM
Dennis140's Avatar
I plan on pulling the cat and cleaning it out tomorrow then inspecting injectors
Old Nov 22, 2010 | 04:38 AM
iselloil's Avatar
You've got a leak in the intake area.Get some carb cleaner and spray the intake and vacume lines.
Old Jan 10, 2018 | 12:43 PM
Redneck28's Avatar
Was wondering what you found to be bad to cause the glowing manifolds mine does this and I can’t figure it out
Old Jan 10, 2018 | 12:51 PM
wyoming9's Avatar
Red face
Almost 10 years ago might be sometime for a response
Clogged exhaust
Timing causing it to be firing with the exhaust valves open
Might be either cam timing or ignition timing
Streetrod19772000
Sep 10, 2015 06:22 PM
Obmi
Sep 10, 2015 03:36 AM
87runner_
Sep 9, 2015 09:51 AM
idadan208
Sep 7, 2015 09:06 AM
