exhaust manifold glowing
First of all its a 95 4runner 3vze limited paid 500 bucks been sitting up three years got it running but manifolds glow thinking cat or injectors clogged any helps is appreciated greatly
Injector would have to be stuck open, not clogged. You are burning fuel in the manifold. Check timing and plug wires, and by that I mean check to see if each wire is connected in the right spot at the distributor and each wire is going to the correct plug. Cat may be plugged or partially plugged.
kawazx636
Jul 3, 2023 03:03 AM
idadan208
Sep 7, 2015 09:06 AM
