Straight plenum/throttle bore swap
Old Nov 21, 2010 | 09:34 PM
Blackulua's Avatar
This is my third set up I've done to a 88 22re
Smoother start up and engine response.I started basically cleaning the plenum
Inside and out with easy off oven cleaner and aluminum acid cleaner.Swapped out the early TPS and cam linkage to the later type Throttle bore.Eliminated the power robbing unit below the Throttle bore and clamped the 2 open water hoses to the throttle bore.I looked up 4crawlers TPS setting and used a ohmmeter to set it within operating specs.
Old Dec 3, 2010 | 04:00 PM
muddpigg's Avatar
Did you use the 7mgt or 5mgt throttle body?
Old Dec 3, 2010 | 04:02 PM
shaeff's Avatar
So you ditched the idle control valve? (that power robbing bit on the bottom of the TB) LOL.
Not worth it for a truck that sees cold weather, but for you in HI, it's bearable.
Old Dec 3, 2010 | 11:43 PM
Blackulua's Avatar
Originally Posted by razed
and the benefit is what?
... same performance as a clean, stock 22re?
The plenum/throttle bore exchange and tuned adjustments really satisfied the owner that didn't know what to do when the truck ran sluggish and a truck with even 529 gears that felt like 390 gears.
Old Dec 3, 2010 | 11:45 PM
Blackulua's Avatar
Stock bore throttle body with TPS swap
Old Dec 4, 2010 | 02:40 PM
myyota's Avatar
The later model 22RE upper intake has better air flow than the early model upper intake with the angled front, there is a small gain to be had by swapping over to the later style upper intake. The gains you see from this mod may not be a lot, but on a 22RE every little bit helps
Old Dec 4, 2010 | 11:18 PM
Blackulua's Avatar
Smile
a proper tune up would've saved a lot of money when compared to mechanical modifications and such unnecessities.
anyhow, thats fine well and dandy adding about 4 hp and barely as much torque.
you got paid well and the client had problems you managed to fix by exclusion.
edit to add- I hope you're not in California. I need a reputable shop to work on my trucks, when I can't fix issues myself.
The parts & modification was done free because we share o lot of Aloha in Hawaii.
Old Mar 7, 2012 | 11:06 PM
Npizzola's Avatar
doing the plenum swap as we speak :wabbit2:
80Truck
Oct 12, 2025 07:25 PM
calderp
Jul 27, 2015 09:58 AM
jjrbus
Jul 23, 2015 05:05 PM
yourrealdad
Jul 21, 2015 11:13 AM
94yotaMI
Jul 21, 2015 05:47 AM
