coolant filter
Old Jul 20, 2015 | 06:04 PM
jjrbus's Avatar
coolant filter
I have a 93 V6, auto with 97K. It sat for a long time.
I can flush and fill and get nice clean water, if I fill let it warm up and drain, there is lots of brown in it. I have done this 5 times and it is getting boring.
So I am thinking an inline coolant filter, did some web searching and wondering if any one has McGivered a one time use cheap coolant filter?
I see an inline hose filter for RV's that might be easy to jury rig in the heater hoses, But some of my thoughts do not pass inspection.
http://www.walmart.com/ip/Camco-Tast...ilter/29764358
Jim
Old Jul 20, 2015 | 11:22 PM
grumpin's Avatar
I would think if you have that much gunk in there it would clog the filter pretty quick. I would not jury rig a filter in because its getting boring. Probably needs a new radiator. And while you're at it, new hoses, and thermostat.
Old Jul 20, 2015 | 11:48 PM
wyoming9's Avatar
Red face
A filter that is any good will be clogged in no time since most are built with a bypass it would just be a waste of money.
It will take time to clean all the rust out.
How many years did it sit??
Old Jul 21, 2015 | 01:53 AM
jjrbus's Avatar
Over a 14 year period it had very little use. How long it sat unused is anyones guess. When I bought it there were 14 year old tires with lots of thread left on them. I have replaced radiator, hoses, belts, including timing, water pump, AC parts an endless list.
I replaced the radiator because of a leak and out of curiosity cut the bottom off to see how much gunk was there, the inside of the radiator was very clean, not what I expected to find.
Coolant filters are commonly used on the big rigs. Thanks for the responses, Jim
Old Jul 21, 2015 | 02:30 AM
jjrbus's Avatar
Doing a bit of searching on this I found a thread where someone documented a coolant filter experiment. For anyone that might be interested.
http://www.bobistheoilguy.com/forums...pics/1965121/1
Jim
Old Jul 21, 2015 | 10:05 AM
wyoming9's Avatar
Red face
One thing to run a Coolant filter on a engine your using
Another to install one on a engine you know still has rust in.
I run a coolant filter on my 7.3
Ran them for years on my Cats
Bottom line it your $$$ Go for it can`t really hurt.
Old Jul 21, 2015 | 10:09 AM
Mr.Utah's Avatar
Just use a basic Prestone flush, follow the directions, clean out the system.
Old Jul 21, 2015 | 12:33 PM
Odin's Avatar
Have you removed the thermostat and removed the block plug to flush the block?
I would probably try disconnecting and flushing the block, heater core, and radiator by themselves then maybe try a chemical flush.
Then do a follow up flush with water from the hose, then with distilled water, drain all, then fill with Toyota red and distilled water. Overkill... but that's me
Old Jul 22, 2015 | 04:39 PM
jjrbus's Avatar
I would probably try discounting and flushing the block, heater core, and radiator by themselves then maybe try a chemical flush.
Block plug? Jim
Old Jul 23, 2015 | 05:05 PM
RustBucket's Avatar
RMI-25 is supposed to clean out the coolant system slowly and gently. I have used it with no ill effects.
I also installed a coolant filter. Not worth the trouble.
the1998sr5
15
Jul 14, 2020 08:35 PM
TACOJO
Nov 27, 2015 05:26 PM
raptor510
Aug 19, 2015 02:15 PM
ddg71
Jul 24, 2015 01:24 PM
ryerye13
Jul 14, 2015 08:27 AM
