- Front Diff Breather Extension
- Overhaul Gasket list? 3vze
- 3vze Flame Thrower Injectors Review
- 1990 3vze 4runner
- 22r with headers leaking aroud water pump and black AND Grey smoke video
- 89 toyota sr5 ext. cab 4x4 long
- Broken Distributor?
- 1988 Xtra Cab speaker size and locations??
- Belt Routing Question (Air Conditioning)
- Just picked up a 87 lifted pick up for 1000 bucks
- parts interchangable from pre 84
- Do glass packs go bad
- "190 HP" 3VZE and Exhaust Question
- No Spark and Air Flow Meter
- Question About Wheels
- 22re Fuel Efficiency + Cat Conv.
- 94 Pickup 4x4, Trouble locating a part!
- 22re MegaSquirt questions?
- My BABY!!!!
- how to tell suspension lift height
- questions about 94 2wd 3.0 auto sas
- Stupidly Basic: Rear Differential
- Chasing Demon
- Help. Need to know if an engine swap will work!
- Question about '91 4Runner front diff housing
- Replacing E-Choke Aisin Carb with M-Choke Weber
- 1987 4Runner 22re, Malfunction code 11
- 91 22re problem
- Alternatives to OEM toyota timing chain set
- Combination Switch Removal
- Rear Passenger Quarter Panel Dent How did you get yours?
- ERG no flow!
- 22-RE Fuel Rail Dampener Elimination Bolt Help
- 22RE HELP - Headgasket
- need some help
- New rebuilt 22re high oil pressure
- 1989 4runner drivetrain compatibility
- Good backspacing and offset for 89 pickup 4x4?
- 3vze bogging hard in overdrive
- cam timing - the hard way!!
- Error code 24 means?
- Aftermarket Awesomeness!
- Rear Anti-Lock Light Help
- Seems like a fuel issue...
- 2.25 inch exhaust?
- 88 yota-Looking for parts
- Wheel spacer Question.
- Decent price for 22re rebuild?
- $3 Noid Light for 22re
- 1991 Toyota Pickup Leaning Passenger Side
- What do you think of my rigs?
- ecu ground wire
- Ifs Help!
- Preserving Frame
- fender flares
- a340h transmission help
- Coolant Line Identification
- wheel bearing seals
- 1992 pickup acceleration issues
- Sudden drop in gas milage
- Weird frontend issues
- Oil leaking around EGR valve
- what size of tire for my yota
- Exhaust leak?
- Time for new head gasket
- 89 22re develops miss after about 30 min
- Plug-n-play alternatori upgrade.
- 1990 A340H into a 1994 4runner?
- Help! 1994 4x4 IFS Diff needed ASAP
- '93 22re running rich, rough idle, backfiring
- Tips on more mpg?\tick
- alternator bolt size?
- Valve cover crack. Replace?
- Oreo! '94 Base Pickup w/ blown HG.
- Adding a second row of bucket seats to extra cab
- Smog Help... Again...
- New rebuild long block, puffs smoke at startup
- Rear Fender Liner?
- Alignment specs?
- Problems opening the hood on my truck
- Just joined the 300K club
- Vibration Issue
- '91 3vze Fuel vapor smell/Hard start
- Fuel Frustrations - 1993 4Runner
- Transmission / Transfer case leak
- 6 puck vs stock clutch
- 2nd gen caliper question
- E-Brake System for 86 4x4 pickup
- 91 pickup with 94 22re sputter prob help
- 89 pickup problem
- Alternator Wire replacement problems.
- 22r vac lines and electric fuel pump conversion questions
- 1990 4runner tail and dash lights not working
- Single wires by the tps.
- 91 4runner Pro comp stage II rear install questions
- 22re help!?
- Transmission or Transfer case?
- 88 r150f won't go to first gear
- 1995 3.o litre Auto Tranny slipping
- 22re with 20r head help
- Trans leak
- Need advice please
- Lift Kits for a '94 4Runner?
- Cyl#3 not firing
- WTB OEM: Spare Tire Lowering Tool & Fender Trim
- DIY: H4 Conversion...
- 1988 w/3VZE - A/C system installation...
- Exhaust hangers, where does other end go?
- 86 2wd clutch issue...
- 88 toy pickup wont stay running help!!!!
- 95 22re running very rough, won't idle
- Frame Restore
- Resonator Box Removal
- EGR Valve?
- Need help with pickup
- Intermittent starting issue: 86 4Runner 22RE
- 1987 22r pickup build and rebuild
- short now hot wire is a ground
- 22RE 5speed transmission issue
- Clearance issues with 2WD Manual Tranny Install
- 95 4runner a/c compressor runs all the time!
- Different 22re idle issue
- auto Trans wont shift to 5th gear 91 4rnr 2wd v6
- DIY Soft top install for under $100 (I spent $84)
- 02 sensor bad? Help!!
- need to get to work, fast anwers appreciated!
- Upper Ball Joint Issue..
- 93 pickup need help asap !!! Please !!!!
- Low Idle: Important Tip
- AC pressure switch
- Small Trailer Towing, Loads, experiences, etc?? And are Zuk's good for this?
- Giving my 4Runner the shift (5spd conversion)
- vacuum line on 92 3.0L 3vze
- 22re leaking oil after timing chain replacement
- Ebay Hurst Shifter
- PS Hose Part Number Help
- oil leak from pass. cv axle connection
- egr block template
- 94 'Yota SR5 pickup, Power Steering Pump & Clutch Line Leak
- EGR Valve Failing = no power?
- Yet, one more "which gear" thread
- '87 Pickup Dash and Parking lights won't go off
- AFM advice
- Front Bearing Replacement Questions
- Newbie 1987 truck question...
- 3vze throttle opener
- Are knock sensors model and year specific?
- shocks?
- A/C compressor location?
- oil pressure
- ultimate off road yota on a budget
- 95 pickup 4cyl struggles
- Mystery leak, having issue identifying
- real oil seal retainer stud removal
- underhood fire , Need help with A/C wiring
- Cranks, wont fire. Cylinder head replace.
- 1990 SR5 lift help.
- 22re toyota pickup
- Transfer case Help
- timing belt keeps slipping!
- gimme your opinions
- 4runner towing capabilities???
- Engine swap 22re 2WD to 4WD??
- Exhaust manifold donut gasket thickness concern
- SAS Brakes NEED HELP
- Head Scratcher - 1991 4Runner w/ 3.0 won't start
- Moving sale! 20% all of our products!
- knocking in engine with acceleration - any advice greatly apprecaited
- Trouble getting going.
- New Cluster, Bucket Seats w/Covers & Console, Hitch!!!
- 1990 4runner knock sensor
- High speed vibration '99 4runner
- Dripping coming from hardline into firewall
- 86-95.5 Drive shaft Q?
- shortening the bed
- 1987 22r pickup motor and trans problems
- rear of truck lifts
- 91 4x4 pickup 3vze clutch problem
- 1990 fuel pump bracket
- Head Gasket finally went
- 22re pistons
- Replacement Hardtop Seal
- 95 4Runner Rear Axle Swap
- Crank case vent
- timing issues rebuilt 22re from a mechanic
- R134 Freon Pressure in a 1994 P/u
- Another V6 tranny swap question
- 22re motor swap from 89 4x4 to 93 4x4
- Fuel problems 88 pickup
- 3VZE Hardline Delete Help!!!
- camshaft 22r
- 22re Help...
- So I made my axle bearing SST
- Transmission Solenoids: How many?
- turning noise in suspension
- Transmission howl
- 1989 3.0 TPS wiring harness
- need help! carb or efi?!
- 91 roll bar brush guard bumper
- Need ecm pinout for 1990 3vze with MT
- Timing chain and clutch - pull engine?
- Dash Pot?
- Power to the Dist?
- VAFM no resistance on vc-e2
- 91 toyota bolt size Qs
- Rear end mona/droan/hum? i dunno, help please?
- ecm Test Mode? 1990 3.0 manual
- Blown head gasket 22R-E
- silly question about wheel bearings
- name this part
- Changing Gearing on Rear end!
- 90 4runner turns over wont start
- rough idle
- 88 runner Crank but no start all of the sudden
- Does 22r 1986 pickup have check engine light.
- Grille/Brush Guard for my 94 4X4 pickup
- Acceleration Problem
- 95 pickup 4x4 throwing 2 codes,21 and 27
- 1991 Pickup Ignition Switch?
- 94 4Runner Start issues
- Camber problems
- 1994 4runner 4wd issues
- Metal radiator line replacment
- check the timing chain
- Bolt sizes
- Crankshaft Pulley Slip.....
- ujoint replace
- 86 idle issue
- 94 Pickup 2wd AC Condenser Fan addon
- She's Flat
- 93 pickup rear lift
- 1988 Pickup fsm. Please link something.
- project toy
- 86 pickup 4x4 not idling once warm... help diagnose
- Broken seat, replaced cables, still won't recline. 86'
- Lock kit
- Need help finding this part
- 95 4Runner Window Switch Inside Spring
- 87 22r smokes all the time
- Clutch
- Rough Cold Start
- Toyota brochure
- What's a good price for >
- 90 4runner transmission problem help!
- 86 22r hesitating when warm, surging
- Symptoms of jumped Timing Chain?
- 22re low compresson
- Weird electric window problem...
