94 Pickup 4x4, Trouble locating a part!
I recently purchased a 1994 Pickup that had a 4 inch lift installed. The lift has taller spindles to raise the A-Arm up 4 inches higher than stock, and it also has cross bracket spacers. I'm looking to remove this lift kit, but my problem is, I can't find the stock, oem steering bracket that bolts on to the inside of the hub, that the outer tie rod end connects to. If someone could help me identify this part, or someone that has a parts truck willing to sell me the left and right side steering knuckle/bracket it would be greatly appreciated. Again, this is a 4WD truck. All I can seem to find is the whole hub assembly WITHOUT the steering piece.
