Clutch
Old Jun 20, 2013 | 07:27 PM
andy4x4's Avatar
Clutch
Is it bad to just do the clutch disk when doing a clutch?
Old Jun 20, 2013 | 07:39 PM
JasonYota's Avatar
I think it depends how bad the flywheel and pressure plate is. But IMO if your changing your clutch go ahead and replace all of it and get your flywheel resurfaced. I don't even know where you can just buy the disc itself.
Why are you changing your clutch? Is it worn out or are you upgrading?
Old Jun 20, 2013 | 07:48 PM
MATTSRED's Avatar
What jason said if your dropping the trans just replace it all and usually if not always the clutch and plate come together. Check your throw out bearing also.
Old Jun 20, 2013 | 08:07 PM
JasonYota's Avatar
When I was doing my engine swap I went to a local drivetrain shop and bought a clutch kit and they resurfaced my flywheel. The kit came with a pilot bearing, throw out bearing, pressure plate, clutch disc, and alignment tool all for I think $180 and that was for a V6.
Old Jun 20, 2013 | 08:21 PM
bone collector's Avatar
well you can just change the disk, but is the money you save in parts worth the time and labor of you doing it twice?
Old Jun 20, 2013 | 11:26 PM
wyoming9's Avatar
Red face
Almost every one I know that has tried to be frugal has complained about having to pull every thing again in a few weeks to a few months.
To answer your question is it bad.
No not really bad just a stupid idea.
This is why you seldom can buy anything but the whole kit!!!
If the Trans comes out it gets a new Clutch Kit
Old Jun 21, 2013 | 02:55 AM
milkybar's Avatar
Yes do it all. Marlin puts together a great kit.
Replace the bushings on the shifter and transfer lever [Marlin also].
Consider doing the Rear Main Seal also if you pull the transmission.
Get hold of a transmission jack if possible, makes the job much easier removal and install.
Old Jun 21, 2013 | 07:07 AM
andy4x4's Avatar
i was thinking about just doing the disk because in a few mouths im doing a new tranny and at the time i do the new tranny i want to put a MC clutch in, my bearings are bad in my tranny right now but i dont have the cash to buy a new tranny yet, but i think i might just do the whole kit now because i dont want something happening in a few weeks
Old Jun 21, 2013 | 07:20 AM
bbrideau's Avatar
pretty hard to buy just the disk. every clutch i've ever bought has been the disk the pressure plate release bearing and pilot bearing, oh and alignment tool. i just did the clutch in my truck. was 155 bucks including a brand new flywheel. If u change just the disk, the old pressure plate and flywheel will chew through the new disk and wear it down faster than a nice smooth resurfaced flywheel would.
Old Jun 21, 2013 | 11:36 AM
wyoming9's Avatar
Red face
If the bearings in the trans are bad !!!
A clutch disc is not going to make it shift better
perhaps a used trans to get you through to you can afford to do it the right way.
You might have said your trans was shot because it is one of those fix it now or spend much more later..
No real answer in that case.
Old Jun 21, 2013 | 01:07 PM
andy4x4's Avatar
i know it wont help shift better do you think im ˟˟˟˟ing dumb, my clutch is sliping
Old Jun 21, 2013 | 01:29 PM
JasonYota's Avatar
If you've got money to burn go ahead and it might last a few hundred miles or longer if your lucky.
And getting an attitude when people are voicing there opinion (which you asked for) isn't very smart.
Old Jun 21, 2013 | 02:33 PM
catfish21's Avatar
We here at yota tech don't appreciate that crap dude you asked for help and your getting help and people's opinion we don't need that here
Old Jun 21, 2013 | 02:44 PM
bbrideau's Avatar
aaaaaaand thread abandoned over some punk ass asking for help and not liking the response.
Old Jun 21, 2013 | 02:47 PM
catfish21's Avatar
You see Andy people don't like this here so just be cool man you can get a lot of info on here don't ruin it
Old Jun 21, 2013 | 04:05 PM
Philbert's Avatar
Go to Pirate4x4 and ask the same question
If Andy used the horus he'd spend pulling and replacing his tranny/clutch TWICE, he could work some overtime and have enough money to replace the tranny and clutch kit next week. #justsayin
OK, I'm outta here - that's the meanest thing I've ever said on YT
Old Jun 21, 2013 | 09:50 PM
andy4x4's Avatar
i was not trying to be a dick, but come on how retarded do you have to be to think a clutch will fix a bad tranny? im not retarded.
Old Jun 21, 2013 | 10:02 PM
andy4x4's Avatar
unless you want to help dont waste my time, and pulling and putting in trannys is so freaking easy i can drop a tranny in like a 30 from when my truck gets in my shop i have done some many transmissions i have it down to a art
Old Jun 21, 2013 | 10:44 PM
wyoming9's Avatar
Red face
Then why would you even need to ask the question!!!!
Old Jun 22, 2013 | 06:59 AM
andy4x4's Avatar
because i was trying to keep it cheap untill i could buy a nice clutch and tranny
kawazx636
Oct 6, 2021 03:03 PM
primordialbeast117
Dec 19, 2015 12:23 PM
smilen724
13
Nov 8, 2015 04:11 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
