90 4runner transmission problem help!
Old Jun 20, 2013 | 02:29 PM
coltonwilky's Avatar
I have a 1990 4runner which has been sitting for about 3 years. I just decided to get it going again so I replaced the fuel tank, fuel pump, and fuel lines. Also changed all the fluids and the water pump and timing belt. Changed the spark plugs and installed a new battery. It started up and runs like a champ. I took it out to drive and the transmission is now shifting very weird, it will not shift until I hit about 4,800 rpms. Please if anyone has delt with this before let me know.
Old Jun 21, 2013 | 05:57 PM
Wobbler's Avatar
Probably just blocked filters in the transmission, have the auto box serviced ( or do it yourself if you can ) .
Old Jun 22, 2013 | 07:06 AM
rustypigeon's Avatar
You can easily determine whether the problem is mechanical or electrical by doing a manual shifting test as described in this link...
http://personal.utulsa.edu/~nathan-b...33manualsh.pdf
The test is easy do to, and will help diagnose the problem.
Jun 1, 2021 01:51 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
Jnkml
Jul 6, 2015 01:20 PM
CJ94yota
Jul 3, 2015 10:14 PM
