Mystery leak, having issue identifying
I have a 95 Toyota pickup 4cyl 4wd 2dr, I recently found a new leak coming from behind the transmission but I'm not sure what is leaking and how to fix it. Please any input will help!
Careful -- gravity is not your friend. A leak anywhere will work it's way down and back, to ... the transfer case.
To find the leak you need to get the engine (really, only the suspect location) clean enough to eat from. Use spray-on degreaser and a garden hose. Once dry, roll it up and down the driveway a few times, then look. You want to find where it is just oozing out on to the clean surface.
rushw
Jul 18, 2015 01:46 PM
