Preserving Frame
Old Jul 10, 2013 | 05:08 PM
milkybar's Avatar
Preserving Frame
Ye Olde Frame Quest.
After doing "a bed off" frame restore/weld on one truck I'm curious if anybody modified [i.e. drilled drainage holes] in their frames to try and prevent those areas from rusting.
I heard that Toyota's new frames are left open so that the debris/salt gets washed out more easily.
Google search didn't come up with anything regards modifying, but this article was informative:
http://www.toyotaoffroad.com/Article.../Rust/Rust.htm
Come on you McGyver's
Old Jul 11, 2013 | 09:22 AM
Flash319's Avatar
I was thinking about drilling holes in the bottom as well. I just got a 93 that I can still read the numbers on the frame (I'm in canada and this is rare around here). The frame has about 1" of mud in it. I have filled it up with chainsaw bar oil for now but I think I will drill holes and undercoat spray inside the frame. I wonder what there thinking was when they did not leave any drain holes on the bottom....
Old Jul 11, 2013 | 05:27 PM
slacker's Avatar
there is only 1 small drain hole .. at the front of the rear spring , front hanger . I open this hole up a bit on all the trucks I do , just to help with drainage . but the BEST thing you can do , like regular maintanance is wash out the inside of the frame with a garden hose
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
RDubya
Feb 10, 2017 04:46 PM
live4soccer7
May 11, 2016 06:52 PM
myotherrideisayoshi
Sep 29, 2015 05:41 AM
