Low Idle: Important Tip
Old Jul 2, 2013 | 03:48 PM
adamthedroog's Avatar
So I've been chasing a low idle problem for years. When it got hot it would idle low and run real funky. I read somewhere on the forums, (I don't remember who it was and can't find the post), where someone suggested removing the idle adjustment screw and cleaning it and the hole it screws into with throttle body cleaner. I did that and no more idle issues and it runs even better.
If you have a low idle issue or if your truck runs rough I highly recommend giving this a try.
Old Jul 2, 2013 | 04:27 PM
ksti's Avatar
What motor? Did you replace the o-ring?.
Maybe put your rig info in your signature.
Old Jul 4, 2013 | 10:18 AM
ToyoTech559's Avatar
yup. should replace the O Ring as well. nothing special just any o ring that fits. this will help with any future vacuum leaks
Old Jul 4, 2013 | 11:07 AM
Inu's Avatar
Inu
As an adon to this. I had an intermitent 200 rpm idle. Turned out the metal coolant pipe that goes to the TB was mostly clogged. Cleaned it out and consistent predictable idle.
Old Jul 4, 2013 | 01:30 PM
the coolant going into the throttle body is needed for the idle air control valve.
nvdesertrunner
May 11, 2020 08:18 PM
Team420
Dec 30, 2015 01:31 PM
Gio8
Aug 27, 2015 12:14 PM
rondogracing
Engine Swaps
16
Aug 24, 2015 03:02 AM
accuracy
Aug 4, 2015 08:05 PM
