PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 [62] 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. no oil pressure registered on new rebuild first starup???
  2. Porting early 22re intake.
  3. Overheating Issues
  4. Rear drum help
  5. Rebuilt22re CANT PRIME FUEl
  6. 94 Pickup Knock Sensor
  7. new alternator...truck won't start
  8. Rear mount turbo 3vze finished
  9. 94 4runner over heating
  10. Clicking sound but won't start up 1990 4runner
  11. 3vze issues
  12. Toyota Fuel Injector Cleaner
  13. 1986 22re shuts off
  14. Replacing water Pump on 90 pickup 4x4 3V6 what else should i do while in there
  15. I need tech info regarding 91 4x4
  16. Clutch problems
  17. 22re loud tick - have video - thoughts? Trying to troubleshoot...
  18. 92 4runner 4wd problem
  19. How much would a paint job be
  20. Steering Gear Box
  21. IFS Re-gear - Carrier side shim issue
  22. Anything wore than a NEW leaky rear main?
  23. some strange noise
  24. 1988 mystery wires... need help
  25. muffler and exhaust questions!
  26. 94 22re what is going on??
  27. Replacing all external seals on Manual Tranny and T-Case
  28. A/C system condensating all over bottom of dash
  29. Running oil pressure light and aftermarket gauge?
  30. High Idle!!
  31. 22re starting problem
  32. Identifying 5 speed manual transmission
  33. What size of exhaust is too big for a 22RE?
  34. Automatic Transmission Cooler
  35. 22re hesitation when warm, rough idle
  36. Ticking Noise at Highway Speeds
  37. what backspacing?
  38. 1995 4runner won't start
  39. My 1991 3.0 just failed NOx....
  40. Moving to Colorado - Is a 22RE 4x4 going to be a dog?
  41. Dumb sway bar problem
  42. 86 4runner Oil Light Stuck On!?
  43. rear shoulder seat belts are in!
  44. Overheating issue on highway and start up
  45. New water pump has tube coming out side
  46. Transmission
  47. Power steering issue
  48. CV axle and tire wear?
  49. Need to know will this work????
  50. Flamethrower Injectors for 3.slo.
  51. Need help with 22RE wiring after 5-speed swap
  52. 93 4Runner not shifting into 2nd gear
  53. connect/wire repair kits? Does Toyota make these?
  54. o/d problem
  55. 22R California Smog Fail
  56. Washer Pump Motor???
  57. AC Condenser Issues -Secondary Condenser???
  58. 86 toyota trans Fluid
  59. Bent axle?
  60. how hard is it to bend an axle?
  61. 3vze dies when clutch in and slowing to turn
  62. Transmission Fluid Change
  63. Switched batt connections, now what?
  64. Replacement Torsion Bar adjustment bolts
  65. zuk mod done!!! Lots of pics!
  66. Washer Fluid and Low Beams Quit Working
  67. Rebuilt 22re won't start need help
  68. spuddering issues
  69. Not starting need some help
  70. Control Arm bushing change! HELP
  71. SAS without lifting???
  72. Need your opinion. Mint 1995 4runner rare find
  73. hey all, new guy here
  74. 3VZE High/fluctuating idle at running temp
  75. Running Hot!
  76. 22R-E Toyota starts and dies
  77. getting ready to do the zuk mod
  78. Valve Shims Mixed!!!
  79. 92 pickup 22re,auto. runs ruff when put in gear
  80. 4runner 1994 steering box help
  81. Help..... Really Smart People
  82. Bad pinion/operating angle fix?
  83. Funny sound while driving
  84. Diagnosing AC system issue
  85. Where to Get Discount Toyota Parts Online?
  86. Are the cv axles useable?
  87. 1st get rear lift
  88. 22re Difficult Crank After Long/Hard Drive and Cooldown
  89. Please give 2nd opinion on fuel leak
  90. IFS Suspension and questions
  91. trail gear shacklle and hanger
  92. DIY Removeable Top Winch
  93. 93 pickup: removing the rear 3rd
  94. question????
  95. Compression Question
  96. Toyota part number finder and truck info
  97. P/S Pump Leaking From High Pressure Fitting
  98. wiring harness clips
  99. Speedometer takes a while to warm up
  100. Needing some help with my 86 yota
  101. 5spd swap question
  102. 92 4 runner
  103. Bilstein 4600 with 1.5 inch of lift?
  104. Dash Lights After Disconnecting Cold Start Injector
  105. 1993 starts but doesn't stay running
  106. 3vze engine code 42
  107. Need Help!!!
  108. Exhaust cracked just after manifold
  109. truck idles and WOT, nothing in between.
  110. Power Steering Cooler...Use Radiator?
  111. fuel sending unit
  112. Need Help Code 12 and Code 14
  113. 86 22r very high idle
  114. 22R suddenly quit running right.
  115. Power steering assist?
  116. yota gods are angry
  117. Drive Shaft Flange Yoke
  118. Strange shifting issues after valve cover and intake manifold gasket replacement
  119. Stuck fuel filter
  120. Question on transmission
  121. dual tcase info
  122. 3VZ-E Hose source
  123. Operator Error?
  124. broke spark plug in head, broke easy out, ideas?
  125. part number assistance
  126. 4wd problems
  127. AT Oil Temp Light
  128. Cranks but wont fre...
  129. my 93
  130. Hard to start the first time on a hot day
  131. 88 4runner
  132. Turn signal/Brake light flash
  133. Bumpers...?
  134. Door slide please help
  135. Twitch
  136. Best way to repair roll damage to my '88 Pickup
  137. Cheapest way to do a small lift to my 94 4runner
  138. TRD LSD carrier??
  139. Not starting
  140. Possible Interior Swap?
  141. '94 3.Slow Idle Issues
  142. I need a new fuel tank but I dont want to spend very much money
  143. bad clutch slave clyinder?! look at pic
  144. 93 pick up 400k miles
  145. my horn hazards dome lights and headlights work but power locks windows dash radio do
  146. One man clutch bleed
  147. 92 3.0 Runner with Fuel/electronic problems
  148. Rear brake pulling?
  149. Serious vibration when braking, help.
  150. Oil Pressure Issues
  151. 22re Timing Chain Cover Bolt Placement?
  152. 89 4Runner heater - w/rear heater - pipe tube repair/fix
  153. An in between camshaft???
  154. 88 4runner
  155. 220k miles on a 22RE 4WD Truck - Too many?
  156. 1995 toyota 4runner code 63 problem
  157. 92 22re hesitates when warm
  158. Water Pump Bolts 2 Sizes 3vze
  159. mpg improvement did nothing
  160. taco coil overs in a 4runner?
  161. On 3rd Brake booster...
  162. 22R Please Help Identify Gasket!
  163. Timing is lost on my 3vze
  164. A/C Idle Up Not Working Anymore
  165. help, 3.0 won't start after rebuild.
  166. CEL, Code 52, no other symptoms ???
  167. hard to find gasket
  168. part number for 92 22re wiring harness?
  169. 3.0 Ignition Timing changed
  170. Leak Down Test Question
  171. Flywheel help!
  172. Flywheel
  173. Alarm goes off after motor rebuild??
  174. 86-95 Pickup and 4Runner Headlight Conversions
  175. Engine rebuild
  176. Rear spewing from the breather hole
  177. Diff decisions....
  178. stock solid front bumper.
  179. 1992 4x4 4runner Real Main Seal
  180. 3vze over heating after rebuild
  181. Best IFS lift kit?
  182. 92 Toyota 3.0 pickup stalls after start
  183. Non-driveline vibration under load and loss of power?
  184. what hubs do I have?
  185. '91 fuel tanks
  186. 94 pickup running hot need help
  187. What exhaust for a 22re?
  188. Acceleration problems
  189. 4runner idling like a pig
  190. Stock Exhaust Pipe Size
  191. Few question about pulling the engine
  192. First toyota and its stuck in 4lo
  193. 22re Distributor
  194. Pulling Trailer causes not to start
  195. 1992 4x4 4runner Transmission
  196. Looking for a good shop to rebuild my 3VZE in LA, CA
  197. 90 4runner 3.0.... what to put under the hood
  198. SAS or Current IFS?
  199. Altternater
  200. Truck wont get hot thermostat tested good
  201. 87 toyota pickup running rough
  202. How Much Can the Factory Roof Rack on my ’93 Runner Handle?
  203. Hesitation and bogging?
  204. Carbon build up on head bolts
  205. 92 4runner leveling kit
  206. Amsoil filters
  207. 1987 starting problem
  208. Cooling lines for transmission
  209. Rims with 4inch backspacing
  210. Friggin code 52-need help please.
  211. Question on transmission
  212. 93 pickup electrical foul-up
  213. What size tires can I fit?
  214. HELP 87 4runner 22re wont start
  215. 3.4 swap pinouts/ TIS help
  216. timing problem
  217. 22re wiring
  218. Gear pop out
  219. Re-installing heads on 3vze with exhaust attatched
  220. Lower Ball Joint recommendation
  221. Crank pulley not seated all the way?
  222. Toyota TIS wiring diagrams
  223. 88 Toyota won't start
  224. reverse idler gear
  225. gauge cluster no worky
  226. 95 4runner turn signal combo switch?
  227. 4Runner supsension/tire mod
  228. Possible for 22R to spit oil from tail pipe?
  229. Brake Line Flaring Tools: Any Recommendations?
  230. How adjust pickup tailgate?
  231. 87 5 speed pops out of first
  232. need a wheel for '95 pickup 4x4
  233. Defeated
  234. 1990 Skidplate
  235. Intermittent starting issue
  236. Ideas for Kill Switch Location?
  237. 3.0 loading up fuel
  238. Coolant Leak- Cannot find the source!
  239. 92 4runner 4x4 3.9Liter Blown Transmission
  240. Will stock k5 rims fit on my 95 4runner?
  241. sputtery 22r
  242. 1991 Toyota 3.0 V6 Timing
  243. 1990 4 runner injector issue
  244. Chnging trany/diff oil
  245. 22RE porn
  246. What is this?
  247. Cruise
  248. 89 4Runner, large oil leak and loud ticking.
  249. New guy with dumb question...
  250. Cel code 22 and 41
