Replacing all external seals on Manual Tranny and T-Case
I need to do a clutch job soon and would like to replace all of the external seals on the transmission and transfer case while I have them pulled. The T-Case leaks a bit anyway (though I am not sure where, and it may be from the FIPG between the two halves of the housing). I have the R150F transmission and the chain-drive T-case.
I have never had one of these apart, so am not really sure exactly which seals I need, plus I really would prefer to have all parts in hand before I start.
Here is what I think I need so far.
Trans input shaft seal x1
Trans main shaft seal x1
Trans output shaft seal x1
T-Case input shaft seal x1
T-Case companion flange seal x2
Here are the parts that RockAuto lists that I am not sure about:
T-Case adapter seal
T-Case chain case seal
T-case output shaft seal
Am I forgetting anything? Are there bearings that can be changed from the outside that I should be considering? Is it easy to split the transfer case open to try to reseal the two halves?
T-Case adapter seal
Staff
I have not got a press to get my main shaft bearing on yet but here is a link>> https://www.yotatech.com/forums/f116...eekend-271102/
Marlin Crawler has a good disassembly of the tcase on his site. Some easy seals to fix there as well.
TURBOrunnerNM
07-22-2015 11:01 AM
Jnkml
07-06-2015 01:20 PM
