Not starting
Old May 25, 2014 | 09:19 PM
Kyleodus's Avatar
Not starting
So just had to start to learn my 89 3.0 and now I'm stumped. Here we go just built a new bumper for it 2 days ago and didn't unhook the battery when we welded on it but ran great untill it just died no sputtering or any thing just dead. Took a look around and the power steering pully had rubbed through the battery ground replaced it cranks but no start. Checked for spark nothing. I got 12v in the wire going to the distributer cap but not sure if that is relavent. Just went and got a new cap and roter going to replace it tomorrow but kind of new to wrenching on engines but I'm not holding my breath on the new cap am roter. Anything else I should be looking at?
Old May 25, 2014 | 09:21 PM
Corey Barlow's Avatar
Did you check the fuses?
Old May 25, 2014 | 09:25 PM
Kyleodus's Avatar
Ya on the side of the road but I just saw a post about the 80amp square one was going to look into that in the morning
Old May 26, 2014 | 08:37 PM
Kyleodus's Avatar
Update so I used a volt meter to test from the coil to the cap. After reading a few post about this topic I did the spark test on the same wire and no spark so going to get a new coil. Things I've done or checked
New plugs, wires, cap and rotor.
Rotor spins when cranked. And all fuses are intact no wire damage that I can see
Old May 27, 2014 | 07:37 PM
Kyleodus's Avatar
Ok update new coil but still no fire so next step is ECM what are your thoughts on a junk yard one
Old May 27, 2014 | 07:44 PM
scope103's Avatar
While it is possible you blew up the ECM, that's pretty rare. It's much more likely you blew a fuse somewhere, or burned through another wire (you already found one).
So, before you suspect the ECM, do the multimeter troubleshooting. My guess is that you will find no 12v there, and you'll be on your way to finding the problem.
http://personal.utulsa.edu/~nathan-b...86troubles.pdf
Old May 28, 2014 | 08:48 PM
Kyleodus's Avatar
ok so im might be being dull when it comes to this wiring, but I hate electrical I don't really understand it (yet) but I put a volt meter on the wire coming out of the coil going to the distributer and I have 12v but if I do the screwdiver in the end and hold it a 1/4 inch from a ground and crank no spark. pulled a spark plug wire did the screwdriver test again no spark (no surprise either had to prove it to someone else) where do I go from here. im don't understand how to read wiring schematics (again hopefully yet)
Doug4320
Mar 24, 2018 10:11 PM
ZONAYODA
Jul 13, 2015 07:17 PM
Poncho0206
Jul 10, 2015 06:21 PM
raiderhawks00
Jul 8, 2015 06:23 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
