3.0 loading up fuel
Old May 14, 2014 | 07:47 PM
mike550's Avatar
3.0 loading up fuel
91 3.0 truck starts up great runs good drive a ways stop shut off try to start it hard starting when it starts it acts like a carbed engine that is loaded up or flooded you have to like cleanit out to get it to run good so a lose on this one been running good till lately smells ritch when your trying to clean it out
Old May 14, 2014 | 09:04 PM
94hiluxZE's Avatar
Its a 3.0 thing. it happens to a lot of us
Old May 15, 2014 | 10:21 AM
rattlewagon's Avatar
Have you checked your TPS and AFM? If they are ok, I would look into the 02 sensor. That seems to be the issue in most 3.0s getting too much fuel. Is your CEL light on? Have you pulled the plugs? What do they look like?
Old May 15, 2014 | 12:37 PM
vasinvictor's Avatar
My brain can't...
Old May 19, 2014 | 06:01 PM
mike550's Avatar
no check eng light the tps is good ohmed it out earlier when it was running bad found that problem had a crack in a manifold vac line replaced it then run great then this started will check the afm not sure how to check the 02 sensor
smthwsn357
May 1, 2024 07:28 AM
Charecter1
Nov 6, 2023 10:08 AM
montanatruck
Feb 26, 2017 07:07 AM
Alex Bessinger
Aug 31, 2015 09:17 AM
tobylab
Jul 12, 2015 12:53 PM
