truck idles and WOT, nothing in between.
Old May 28, 2014 | 07:26 AM
npbryden's Avatar
I have a 1990 toyota pickup 22re that developed a problem about a week ago. The truck starts up and idles fine but as soon as you rev it up, it wants to die, or if you put a load on the motor in gear it wants to die..unless you push the pedal to the floor, then it takes off and revs up great. I was thinking maybe TPS or AFM but I dont get a check engine light. Any other suggestions? Thanks!
Old May 28, 2014 | 08:29 AM
scope103's Avatar
Where is the timing set?
Old May 28, 2014 | 10:17 AM
crash813's Avatar
Have you checked the o2 sensor? When you're in closed loop....ie, not idle or WOT, it uses the o2 sensor to maintain fuel mixture.
Old May 28, 2014 | 10:44 AM
Gamefreakgc's Avatar
Check timing first and then do a simple TPS check using a multimeter and a service manual. My initial guess is that your TPS is so out of whack that it doesn't realize it's out of idle until you completely open the throttle.
Basically, yeah the ECU thinks you're in open loop because a sensor or something is way out of whack.
Old May 28, 2014 | 11:19 AM
vasinvictor's Avatar
If you'll simply unplug your TPS, go for a drive and see if it's better. If you unplug your TPS, your truck will go into open loop. If it's better, TPS problem, if it's not any better, better look elsewhere.
Old May 28, 2014 | 06:49 PM
npbryden's Avatar
Thanks for the help guys, I metered the TPS and it metered OK, i will unplug it and see if that helps any though. Also I will try to get a different o2 sensor to put in. As far as timing goes, doesn't a clean idle and clean WOT mean timing is OK? I have never checked timing but I will look up how to do it.
Old May 28, 2014 | 10:25 PM
scope103's Avatar
Originally Posted by npbryden
... As far as timing goes, doesn't a clean idle and clean WOT mean timing is OK?...
No. A timing light is $20. http://www.harborfreight.com/xenon-t...ight-3343.html That, and a multimeter, is part of the minimum equipment you need if you want to work on your own vehicle.
Old Jun 25, 2014 | 07:01 AM
npbryden's Avatar
Ok, so we figured it out, turns out the fuel pump was going out, it was only pushing 20psi when it should have been 35. Changed pump, runs beautiful again, thanks for you input guys.
Old Jun 25, 2014 | 04:13 PM
Glad we could help by all being way off from the actual problem
Yont283
Sep 23, 2022 08:06 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
slider417
Jun 22, 2015 10:18 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
