Cruise
Old May 14, 2014 | 05:28 AM
bigkev8's Avatar
Cruise
Having a problem with my Cruise control! The light goes on, but it won't set a speed. Does anyone have any idea's on how to fix it?
Old May 14, 2014 | 05:31 AM
scope103's Avatar
Codes? http://personal.utulsa.edu/~nathan-b...10cruiseco.pdf
Broken throttle connection? Disconnected vacuum?
Old May 14, 2014 | 09:25 AM
bigkev8's Avatar
don't have codes! Throttle cable is good, vacuum line is good. it goes to a module on engine, maybe that is plugged?
_____________________
1988 4runner all stock!
Old May 14, 2014 | 10:03 AM
Gevo's Avatar
FUnny thing, my cruise was working fine a while ago, but the other day it wouldn't turn on...
With that said, the only time this week engine handles cruise control properly is on long flat terrain. So, my suggestion is to lube your gas pedal and make it soft
Old May 14, 2014 | 10:19 AM
Gamefreakgc's Avatar
Check the play on the cruise control cable. Sometimes it stretches and the vacuum then doesn't tighten the cable enough, making the speed drop. It adjusts in the engine bay at the throttle body. Make sure it's tight with only the slightest movement but does not hold the throttle open.
Old May 14, 2014 | 10:23 AM
scope103's Avatar
Originally Posted by bigkev8
don't have codes! ...
Did you run the tests starting on page BE-80? If not, then all you are asking for is people to guess something.
Old May 14, 2014 | 10:48 AM
RJR's Avatar
RJR
What scope103 said. The cruise control system has its own separate diagnostic system, independent of the engine control system. Codes won't show up with the normal test methods. You have to run the diags as per the service manual link he gave.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
Badlander
Jun 20, 2016 07:20 AM
Shagool22
Sep 28, 2015 07:53 PM
Tcsdef
Sep 7, 2015 11:17 PM
