- 2nd gen Lift
- What do I do now? - Head/Sparkplug mess
- 3.0 Jumping when put into gear
- Anyone change e-brake cable on 2nd gen??
- Battery discharge light came on!
- 95 2wd 4runner specs help
- Wheeling pics...BIG PICS!!!
- 2nd gen 3rd Row Seat Dilemma
- Does anyone have a picture of a 2 door 2nd gen 4Runner
- swapping to diesel
- Audiovox Cruise install 89 22re Automatic settings?
- need engine
- my electric fan drained my battery!!
- How much fender trimming?
- 1988 4runner engine rebuild, 3.0 V6
- Help Me Decide- couldn't find poll
- Just made 300K
- Tach bounces and CEL flashes
- replacing shocks
- Interval for Repacking Front wheel bearings 4wd ?
- 2nd gen/3rd gen seats
- Non-Newbie Seat Question
- possible to swap 3rds instead of regear?
- Aftermarket Muffler & Cat.
- Wires on valve covers
- Brighter headlights?
- "Weak" A/C Compressor on 3VZE
- Truck back from shop now transmission lurches/jolts
- trying to figure out rpms at 80mph?
- Long road trip with the trusty 22re?
- Something's up with the 4wd PLZ HELP
- 93 4Runner Front Bumper
- Trim/remove rear bumpstops?
- Does anyone have the Magnaflow direct fit Cat?
- Rear end noise
- Truck price - moving
- Would this tape deck fit in my '95 4Runner?
- neebie buying a 4runner
- Doing the HG on my 3.0 anything thing I should do while down this far?
- 1989 thru 1994, 4Cyl vs. 6Cyl ???
- My cure for a knocking 3.0
- Wiring for a trailer.
- 3.0 v6 ignition timing
- What rear shocks W\HD coils?
- Help Check Engine Cel codes Trans codes Brake codes
- Going Though yota withdrawl
- sunroof
- Body lift\front bumper on 94 pickup
- newb with a seat question
- used lift advice
- CV Axle angle?
- Backspacing stock SR5 rims
- Just "Clicks" sometimes I try to start it.
- Rebuilt engine not running right...
- Blown Head Gasket
- rear driveshaft options; 4" lift
- got a busted TVV sensor? fix it! (pics)
- best place for new catalytic converter for my 3.0
- Turn signal issues
- 3.0 Leaky, Leaky
- antifreeze leak. I'm thinking the water pump...
- Bent fuel line?
- Mods on hold - Truck died and wont start :(
- Can't keep water in her.......
- Ground wire locations? 90 PU 4X4 3.0
- engine will not crank all the time
- Degreasing engine to look for leaks
- 3VZE 1990 Removed air intake manifold, now won't start! Amature? TOTALLY!
- Intake Manifold Removal
- For guys running a DOA/LC cam on thier 22re
- Any pics of aluminum dash trim
- When adjusting valves how far is engine turned?
- What is the alternative to stock air filter on 3.0
- 22RE, running bad at low rpm
- Timing chain change now slight idle rattle
- 22re 22r interchangable parts??
- Tires/Wheels
- Power steering pump rebuild
- Idler arm adjustment?
- Check Engine Light after hitting 2500+ RPM
- Custom dash ideas?
- need help BAD, terrible idle and smoke
- 88' 4runner Throwout Bearings?
- piston slap-is it worth fixing?
- throttle position sensor Problems
- Engine Starting Problems
- taking off front rotors on 4x4
- noise after balljoint spacer
- Installed 7" lift in my 4runner yesterday!!! PICS!
- 3.0 wont stay on
- Coolant on top of engine block...No. 2 idler leaking?
- AAL in Canada
- New Engine Installed - Troubleshooting Help
- CEL Code 25 - Most common cause
- Leaks?
- tight valve clearance cause low compression
- very low, choppy idle...
- clutch problem
- Removing brake discs
- Locking Hubs
- Removable top problems...
- OME900s installed - opinions on torsion bar crank? (pics)
- Bud Built and a ARB Bumper
- Still have starter problems ???? :P
- 95 4Runner starting problem
- exhaust options for a 86 22re
- 22RE Front Main Seal Leak, Dangerous?
- please help on harness from engine to 02 sensor
- 87 4Runner Digital Dash, (Combo Unit)
- Relocating the cat?
- Broken Egr Valve Tube - Need
- Wheel play "with camber" (up/down)
- bigger brakes
- Do new heads have the valves adjusted
- Have the truck now, but where to start
- Upper control arm issues.....
- squeaky brake pedal
- Strong smell of gas...not exhaust...GAS!
- 80's Graphix
- 89 toyota truck load sensing proportioning valve
- Suspension Lift...
- I scanned the Electrical Wiring Diagram book
- 3rd Gen Power Window buttons in 2nd gen?
- New Member-Looking at 95 4Runner
- 89 to 93 engine q'
- Truck runs strong, but have laundry list of repairs. Is this possible?
- 3vze pointers
- a/c conversion problems.
- Drain block of antifreez to drain heads
- What is this plug on top of my diff? (pic). My 4.88 diff has it my 4.10 doesn't?
- Good Radiator Company?
- Anybody running stiff Monroe shocks?
- 91 SR5 p/u rear view mirror with lights
- wtk: new pitman arm damaged
- Runner wont stay started
- Can we drive without the A/C Compressor Belt
- Code 14
- third row seats
- Body lift pictures please
- Rear seat covers that cover the BACKs?
- 3.0 HG replacement tech writeup?
- Another Torsion Bar thread
- Chevy wheels on a 1st gen 4Runner?
- WOW! H4 conversion w/4crawler harness!!
- 1986 Hilux Surf running rough when warm
- which wheel bearing
- magnaflow muffler questions
- Replacing belt 94 P/U
- Rear trailing arms and lift height
- How tall are reg cab drivers?
- painted fender trim plus new tires (pics)
- 100 Series IFS Cruiser Coils in 2nd Gen - 5" Lift
- 3vze pull/install w/ trans attached (pics)
- Front Parking Brake Cable...
- 2nd Gen 4Runner Swaybar discos
- Tuffy console?
- Dissolve Intake/EGR Carbon?
- Hand Brake Conversion?
- 91 p/u V6 starter
- Trans Problem
- cutting torsion bar bolts - hazardous?
- help with power window motor,drivers side front
- 35's on 88 Runner w/2"BL (searched)
- 86 4Runner brake failure. . .
- wiring for painless brand dual-battery solenoid switch
- Disabling ABS
- Spare Tire Mounted on Hood
- Steering columns.....
- Changing CV axles
- locking hub question
- shorten tie rod ends for 4" ifs lift?
- Humming Hub
- Fuel injector o-ring leaking
- '88 Bed & Seat
- 3.4l swap
- anyone running 33's and 4.10's? (22R-E) MPG? driveability?
- 3FZE transmission shifting rough...
- 1st post - need some help (new engine)
- TPS adjustment???
- Chaos Fab users
- "breather box"?
- Blower motor
- Istheis a good deal or not ?
- how to remove crank gear ?
- SeaFoam
- Why did Toyota run twin hard-lines to the rear brakes?
- Engine Service Code
- Burning oil/oil pressure question on 3.0
- AC Leak detector
- Body Lift?
- IFS is not weak, the 7.5 diff is....
- Clicking Sound
- Permanently removing ABS actuator?
- sleeping platform finished! many pix
- steering rod recall
- CV to Diff flange removal
- #2 cylinder?? not working
- Wet Okole rear seat covers
- 3/4 Satoshi
- Does anyone make a longer CV boot? (searched)
- Free O2 sensor replacment
- Noticed something funny when changing plugs
- 3.0 to 3.4 swap do you use same computer
- New Fun Problem: Won't start when its hot outside..
- Post Halfshaft Replacement Issues
- heavy duty coils for lifted 95 4runner?
- Overheating?
- What are my odds of replacing the camshaft on my 22re without busting the head gasket
- how much coolant to use on a 3vze
- Massive Coolant Leak
- lookin for tires
- stripped bolt on the manual transmission
- New Magnaflow catback system, Arghhhhhhhhh
- any ramifications on driving with burnt valve
- Which gears
- Manual or Auto?
- Electrical gremlins on '88 Pickup... Please help!
- timing and power on 22re
- does a K+N FIPK filter kit help much?
- torsion bar on the driver side
- Hilux LSD diff installed now vibration
- Engine Hesitation, whats happening?
- Well Finally Got it Fixed
- *RUSH* Setting Timing...
- No Brakes!
- Barely passed smog today
- Requesting advice on replacing front and rear bumpers
- Waiting for online parts...can't sleep...
- 95 4Runner - Fuel Pressure
- Is there any point in starting another build-up thread?
- Winch bumper
- oil leak
- Check out my Grill
- Oil pressure guage
- 3.0 camry supercharger?
- Pulling engine-leave trans and transfer case attached?
- 3vz-e Power Loss Reasons?
- Used car things to check/do etc.?
- Urgent: Bearing job via oil pan in progress, what to do?
- SAS cheap?
- Anti Knock sensor 22RE
- 488s vs" 529s ?
- Manual hub convert, cv too short
- new BJ spacers & coils, too much forward lean!
- front end *clunk*
- fuel filter location
- reliability of motors
- Getting my dash put back in......pics
- Disabling factory alarm on 1990 4runner?
- 3.4 out of a 95 t-100 into a 91 4 runner
