New Member-Looking at 95 4Runner
Old Apr 20, 2006 | 07:09 AM
homerun's Avatar
Hey everyone,
I'm a new member here
I have a question, I'm looking at buying a 1995 SR5 4Runner. It's got 150K miles on it, which doesn't bother me. I spoke to the owner, and most of his miles came from his previous commute, which was 90 miles round trip. Since changing jobs, he's now commuting 18 miles, round trip. So, the large majority of miles are highway.
I'm going to look at it tonight, but I haven't owned a 4Runner before-what are some things I should look for?
He's had some work down to it already, and reading other posts on here, head gaskets seem to be an 'issue'. But it looks like he's already had that problem and took care of it. Below is more info on what he's had done:
Extened range remote start; new engine parts-head gaskets, timing belt, water pump, power steering pump and steering link; trailer receiver and brush guard just powder coated; tires still have lots of tread; sun roof wind deflector; bug/rock deflector; wood grain dash; well maintained and have all service records; all highway miles and never used to tow; gets over 20 MPG.
He's asking $5,300.00.
Any advice would be greatly appreciated!
TIA....
Old Apr 20, 2006 | 07:21 AM
cootees's Avatar
Looks like you did your research. The headgasket was a factory recall. Other than that just look over it for leaks and what not but it sounds like the owner maintained it well. It should server you for a long time.
Oh yeah, don't be suprised of how slow it is when you test drive it. Thats the famous 3.slow.
Old Apr 20, 2006 | 07:31 AM
homerun's Avatar
thanks cootees,
I'll defintely look it over good.
Old Apr 20, 2006 | 08:43 AM
snap-on's Avatar
crawl around underneet looking for oil leaks....
oil cooler (on the drivers side of the block) can leak... the Power stearing pumps like to leak, the oil pan gaskets like to leak, the valve cover gaskets like to leak. (this is all just due to age and is all fairly simple stuff to fix and shouldnt be a deal braker)
Old Apr 20, 2006 | 08:47 AM
4mydogs's Avatar
Snap-on beat me to those items. Just make sure you give it a good going over -- you said you're going tonight? Don't make a deal until you see everything in the light of day, and I recommend you have your fav mechanic check it out, too. Other than that, good luck! And let us know if you buy it.
Old Apr 20, 2006 | 08:52 AM
homerun's Avatar
Thanks guys...
I said this evening, but it'll still be daylight out. As for the mechanic checking it out, the car is over an hour away, so that would be tough, logistically.
Does anyone know what type fo gas mileage I should expect. I live in a more rural area, and most of my driving is two lane road at around 45-60mph. The owner claims (on the phone) 22 on the highway.
Thanks
Old Apr 20, 2006 | 09:03 AM
4mydogs's Avatar
There are LOTS of threads on gas mileage here. V-6 or 4 cylinder? 2WD or 4WD?
My V-6 4WD gets 15-19 mpg all around usage.
Old Apr 20, 2006 | 09:11 AM
homerun's Avatar
sorry, I didn't put that in. It's a 3.0 4WD.
I looked through some, but I'm still trying to figure out engine types, plus some have larger tires.
Old Apr 20, 2006 | 09:39 AM
celica's Avatar
there is a difference in fuel economy between the auto & the manual
Old Apr 20, 2006 | 10:49 AM
homerun's Avatar
I did some more searching and found the avg. is around 17-some higher, some lower.
I was hoping for better.
I talked to my brother who gets 16mpg in his 93. I believe it has the same engine.
Oh well, I'll keep looking.
Old Apr 20, 2006 | 11:35 AM
4mydogs's Avatar
The 5-speed typically gets a few more mpg than the auto. Since my last tune-up I've been getting close to 20, which is as good as I've ever got. BTW, mine has around 146K miles on it, so it's right about even with the one you're looking at.
Old Apr 20, 2006 | 12:55 PM
homerun's Avatar
thx..
If I decide to get it, maybe I'll pick up an eco-systems filter. Probably couldn't hurt.
4mydogs-have you had any problems with yours'?
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
