Runner wont stay started
Old Apr 19, 2006 | 02:29 PM
86RNRNICK's Avatar
It will start and die right away the first two tries. after that, it doesnt turn over. it tries, but the engne doesnt fire. i dont know what to think of it. it was running fine a few days ago and then this happened. Also, when i turn the key to the on position, my check engine light doesn't come on. at all. Does anyone have any tips or suggestions. I dont know what it could be. i check the fuel pump, the spark plugs. battery is fine. i can't figure this one out. any help would be greatly appreciated!
Old Apr 19, 2006 | 02:39 PM
celica's Avatar
is the VAFM plugged in? Is there an air leak in the intake or other vacuum leak?
Old Apr 19, 2006 | 02:41 PM
91_4x4runner's Avatar
Maybe the TPS is completely haywire, or the idle adjustment?
Old Apr 19, 2006 | 06:07 PM
regularguy412's Avatar
Does this occur when the engine is overnite cold, or does it do it with a warm or cold engine? If cold, could be the cold start injector or low fuel pressure ( plugged filter or failing pump). Mine had similar problems and it turned out to be the fuel pump.
Mike in AR
Old Apr 19, 2006 | 06:16 PM
AH64ID's Avatar
check the ECU fuse, or any other fueses under hood...
Old Apr 19, 2006 | 09:09 PM
86RNRNICK's Avatar
I cant get it started at all. its in the middle of the day. i guess you could say its warm. idk. i checked all fuses and they are fine. im thinking it a sensor. not sure.
Old Apr 20, 2006 | 04:52 AM
Even in the middle of the day if it's not been running at all, that's a cold engine. Test the cold start injector.
Mike in AR
Old Apr 20, 2006 | 10:56 AM
86RNRNICK's Avatar
It started before. And that doesn't really justify why it would turn over and die twice and on the third time, wont. hmmm.....
JF9243176
Oct 8, 2017 04:21 AM
voiddweller
19
May 2, 2016 09:10 PM
camdenbuck
Jul 7, 2015 07:33 AM
bigblue82
10
Jul 6, 2015 08:27 AM
serenity03k64
Jun 27, 2015 07:59 AM
