When adjusting valves how far is engine turned?
Old Apr 23, 2006 | 04:20 PM
jjenks0's Avatar
I am getting ready to do a valve adjustment and I am curious if any one knows how far to turn the engine each time? I do not want to compress a valve into my piston.
Thanks.
Jack
Old Apr 23, 2006 | 05:00 PM
AH64ID's Avatar
usually you rotate it one revoultion...unless your timing belt is messed up you shouldnt impact a valve and a piston...
Old Apr 24, 2006 | 03:35 AM
jjenks0's Avatar
The timing belt is still on but will be replaced. So if I have the timing set at 0 and adjust the valves that have the lobes up and then rotate it 360 degrees I should be able to do the other valves?
Old Apr 24, 2006 | 07:14 AM
AH64ID's Avatar
I havent ever done a 3.slow, but thats the way every other engine I have done it.... remeber your just rotating the engine thru its normal rotation, shouldnt have a problem. Pick up a haynes or a chiltons or a FSM...they will detail it out.
Old Apr 24, 2006 | 07:57 AM
jjenks0's Avatar
I have a haynes but it does not seem to talk about a valve adjustment. Just how to take them apart.
Jack
Old Apr 24, 2006 | 08:35 AM
Buck01's Avatar
see if this write up helps you.
http://www.off-road.com/toyota/tech/...ves/index.html
Old Apr 24, 2006 | 12:49 PM
AH64ID's Avatar
I dont know about haynes, but in chiltos there in different parts of the book,
Old Apr 24, 2006 | 12:55 PM
Yoda's Avatar
We assume you have the special tools and an assortment of the shims?
Yont283
Sep 23, 2022 08:06 PM
jennygirl
Nov 17, 2015 11:24 AM
Jmiller1023
23
Aug 6, 2015 07:03 PM
88Toy
Jul 4, 2015 02:11 PM
Taz22R
Jun 21, 2015 04:44 PM
