3.4l swap
Old Apr 17, 2006 | 05:47 AM
rwhite's Avatar
3.4l swap
I"ve tried a search and nothing answered my questions. I have a '86 4x4 with a 22re engine. I also have a complete '95 Tacoma 4x4 that is totaled, but it good engine tranny and transfer case, and all wiring. Both are manual trannys. I know that I'll need to make motor mounts, get a 3.0l oil pan and cut the hood. How do I handle the transfer case since the differential is on the opposite side? Do they make an adapter plate that will mount the 22re transfer case to the Taco tranny? Any other parts you can think of would be helpful. Or a link to someone wh has done it. I found one link but they used dual transfer case set up, and the wiring was not addressed. Thanks for any help.
Old Apr 17, 2006 | 08:07 AM
AH64ID's Avatar
www.offroadsolutions.com
Old Apr 17, 2006 | 08:47 AM
anthony1's Avatar
You want to keep your Trans and t-case. I dont' think the tacoma t-cas is gear driven like the one you have. If you plan to go dual cases or regear your t-case low, it'll be more common.
There are folks out there that have done this successfully. Search the 4x4wire.com also.
Old Apr 17, 2006 | 09:30 AM
rockota's Avatar
Actually, he won't be able to keep his trans, and even if he could, it would last only a few months before falling apart - that G52 can't handle 190HP.
Put the engine and tranny in the truck, buy an R150->gear drive tcase adapter from Marlin or Inchworm and you're all set.
Definitely work w/ ORS.
Old Apr 17, 2006 | 09:42 AM
Keggo's Avatar
You should sell the 3.4L and get a supra engine. From what I hear, the 7mgte mounts pretty well to the stock 22re motor mounts.
Old Apr 17, 2006 | 09:57 AM
mt_goat's Avatar
Originally Posted by 4x4nala
X2, I know Mike has done a 22re to 3.4 swap (Bill's red chili) but according to Bill it was a PITA for him: http://www.4x4wire.com/forums/showfl...ev=#Post844892
Old Apr 17, 2006 | 10:51 AM
anthony1's Avatar
oh, I thought he had the stronger trans...sorry.
Old Mar 31, 2007 | 09:39 AM
DeathCougar's Avatar
huzzah for old thread revival...
but
Since I am doing the 3.4L swap soon, I want to use the 3.4 manual trans, and re-use my gear drive tcase (86 4runner).
I noticed marlin has an adpater for a gear drive case to the 99 4runner tranny. Has anyone used this adapter before? Can anyone give me guidance on what all has to be done to adapt my W56 gear drive case to my R150 994Runner transmission?
Reasoning for all this is ease of install, and lower expense. If I can just use the gear drive case on the 99 4runner trans, I wont have to go purchase a T100 tranny, thus saving me hundreds.
mussy01
Dec 13, 2016 08:20 PM
1996Taco
Jul 20, 2015 12:02 AM
taller1
Jul 16, 2015 03:00 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
