TPS adjustment???
Old Apr 16, 2006 | 08:06 PM
bigpest88's Avatar
TPS adjustment???
How cay you tell if your TPS needs adjustment? Can you adjust the TPS on a 3.slow motor If so, how.
Thanks,
ChRiZ
Old Apr 16, 2006 | 09:50 PM
Elvota's Avatar
You can adjust the 3.0 TPS and this is how...
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
It is easier to do with the throttle body off the engine.
Old Apr 17, 2006 | 04:59 PM
anthony1's Avatar
one of the way ( for me anyway..) is when you check your timing, you need to jump the two terminals. If it doesn't change the idel speed, chances are the TPS is bad.
Old Apr 17, 2006 | 05:03 PM
runethechamp's Avatar
Those instructions are for the 22R-E engines and are not completely accurate for the 3VZ-E. See here for the correct instructions: http://personal.utulsa.edu/~nathan-b...93throttle.pdf
zytra
Jan 24, 2019 03:16 PM
ZGjethro
Jun 7, 2017 11:04 PM
the_supernerd
Oct 1, 2015 09:20 PM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
dbollier123
Sep 29, 2015 05:23 PM
