very low, choppy idle...
Old Apr 21, 2006 | 07:19 PM
mtrdrms's Avatar
My 89 3.0 runner has been running crappy for a while now and i am getting fed up. I replaced the coolant temp sensor and the cat converter but nothing has changed. It is not throwing any codes so I cant really narrow it down. Any ideas? Some have siggested the EGR valve but how do you test it? It runs very low idle (100-500rpms) all the time other than that it runs fine. Thanks
Old Apr 21, 2006 | 07:48 PM
95RunnerSR5's Avatar
i had that same problem on my old motor...i have no idea what it was
Old Apr 22, 2006 | 02:53 AM
8422r4Runner's Avatar
Have you checked the air filter, the top can be new looking, but if you pull it and look at the bottom, it's dirty.
Old Apr 22, 2006 | 05:24 AM
mtrdrms's Avatar
yeah the air filter is good.
Old Apr 22, 2006 | 02:54 PM
rpeAMP's Avatar
The only problem is the low idle? I had a #6 plug that had a cracked electrode that cause all sorts of problems, including a low, bouncey idle, and violent shaking when starting the truck cold. Any misfiring or stumbling?
Old Apr 22, 2006 | 03:26 PM
nmtoy's Avatar
Have you checked your coolant level?
Old Apr 23, 2006 | 06:50 AM
mtrdrms's Avatar
No misfiring or stumbling when driving. It runs great and is getting 20mpg (which I consider good). The only problem is the very very low idle. It sounds like it may be missing or stumbling at idle. The coolant level is fine.
Old Apr 23, 2006 | 08:05 AM
taikowaza's Avatar
I did a few things that really helped with my 2nd gen 3.0 V6 idle.
changed spark plugs, wires and rotor. Adjusted idle speed by turning the screw (remember- it should be at 800 RPM when warm, not when just starting out. My RPM starts at a little over 1000 and drops to 800 and stays there after driving a bit. I also cleaned the throttle body and finally sucked a can of Seafoam into the engine. I also got an Optima battery (prob. didn't affect idle). This combination of things really did wonders for my idle and it purrs like a kitten, no problems. Good luck!
TW
1992 4runner, Thorley Headers, Jardine Exhaust, Magnaflow Cat, OME Steering Stabilizer, Downey Idler Arm Gusset, FIPK, Optima Red Top, WAAG brush+rear guards, PIAA 520s, TOMTOM GPS on Treo 650
Old Apr 23, 2006 | 09:55 PM
Bobakazi's Avatar
Vacuum leak? With your engine on at idle, spray some starter fluid around your vacuum hoses, intake, throttle body, gaskets, and see if your idle drops because of the spray. Could be a vacuum leak.
Old Apr 25, 2006 | 04:06 PM
mtrdrms's Avatar
vacuum leaks generally raise the RPMs dont they? Ah well I checked and came up with nothing. I also jsut replaced the plugs, wires, cap, rotor. Also checked the oil and coolant and it doesnt appear to be head gasket problem. so its off to the dealer tomorrow to get checked out. Any last ideas before I shell out an arm and a leg to get it fixed!!?!??!
Old Apr 25, 2006 | 04:20 PM
toyotaoffroad91's Avatar
if you spray "starter fluid" the idle will raise id recomend carb or brake cleaner nad see if the idle drops plus its safer then spraying a bomb all over your motor
Old Apr 27, 2006 | 07:04 AM
mtrdrms's Avatar
Good call. It was a vacuum leak. It turns out the EGR valve was cracked and was causing a major leak. I replaced it and the truck runs beautifully now. Thanks guys for the input.
Old Apr 27, 2006 | 09:00 AM
Bobakazi's Avatar
Glad it is fixed! BTW, I intended to say the idle will smooth out if there is a leak. Sorry for the miscommunication. Starting fluid, carb cleaner, propane, all good.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
Longbed 90
Mar 11, 2019 12:38 PM
bhaithc
Sep 17, 2015 07:53 PM
Boomer8404
Sep 10, 2015 09:01 AM
