PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 [223] 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Brush Guard fun
  2. Head Rebuild
  3. need help: how to adjust IFS alignment cams
  4. Replacing Starter
  5. 3.0 engine troubles, electrcial gremlins& leakiy o/f
  6. 2 dumb questions
  7. need some help asap about my guages
  8. 2nd gen air intake!
  9. 22RE Missing / Sputtering at Idle!
  10. $50.00 paint job
  11. 1990 4Runner
  12. 2nd. generation ISR mod woes
  13. white smoke
  14. New lights but now a glare issue
  15. Problem AC
  16. any advice on pulling gas tank
  17. 86 4runner transfer case problems???
  18. Leveling question
  19. Thank you everyone!!! Success!!
  20. Turn radius?
  21. OME 901 / BJ spacer lift for sale
  22. Bilstein/Downey HD Combo
  23. 22re to to 3.4l conversion
  24. 3vz-e broken valve spring
  25. Decent tire?
  26. Yopar Project
  27. 94 pickup passenger headlamp
  28. Runs warm, A/C shuts down
  29. Help me identify my T-Case
  30. Alert!! 514 Recall Campaign Error
  31. 86 22r 4speed, suttering like its flooded out
  32. fuel filter help 22ret
  33. Help!!!!!
  34. update on code 52 erratic idle 3vze
  35. heating issue.
  36. Adjusting the carb
  37. Getting Ready For My Close-Up, Mr. Demille! No 56k!
  38. Pic Montage Vids From this Year...
  39. Anyone ordered parts from Mizumo Auto Parts via eBay before?
  40. Factory Alarm Pin Out? (95')
  41. Idles great - runs rough under load...
  42. Tire/wheel size change question.
  43. a little help please... where is the ac compressor located at.. pics inside
  44. Question for all the 86-88 pickup and 4runner owners... Bumper related
  45. 22R vs. V6
  46. Runner got a new home yesterday
  47. Alignment needed?
  48. My Fellow Phoenix yotatech memebrs..Tech Day is now here
  49. 1988 4runner 3.0/auto t-case issue
  50. got mud?
  51. Quick question regarding license plates
  52. will a toyota v6 motor bolt to a 4 cylinder transmission
  53. painted the stripes on the 89
  54. for all with a snorkle
  55. New Here
  56. '86 bed
  57. runs poorly unless I heat it up and turn it off and on
  58. 2wd 1-ton Toyota Dually Axle
  59. Clicking while braking in reverse only
  60. New Toy
  61. Some Duplicolor pictures
  62. tranny problem
  63. Ok 4Runner Speakers: What worked - What Sucked?
  64. Getting ready to do the HG repair, checklist
  65. 3vze Throttle body vacuum hose
  66. 90' Pickup Exo Cage
  67. should i replace brake cylinders?
  68. screeching noise when starting from a stop
  69. Kickdown (Detent) Cable
  70. A/T Oil Temp, Brake, Charge Light All On...............HELP!!!
  71. After a good buff n wax
  72. 86' 4Runner! Just purchased
  73. Just picked up an 86' 4Runner
  74. Timing guide broke sortof? Driver side.
  75. 92 4runner trim question.
  76. 22RE Idle Problems....Help!
  77. Help replacing rear wheel bearing?
  78. 3.0 engine swap with jdm... ecu problems?
  79. exaust size?
  80. HG Repair or rebuilt engine?
  81. Fiberglass Q - making a cab floor
  82. Ngk Spark Plug ?
  83. Muffler and Catalytic converter 94 EX Cab Pickup
  84. Gen1 4 Runner slider window L trim
  85. Engine/transmission separation problem
  86. Why would my tcase output have RTV on it?
  87. Spacers for Center carrier bearing?
  88. Recommendations for Ignition Wires
  89. bad grinding sound
  90. Seaform help?
  91. 88 rear axle "play" amount??
  92. OME Coil Install Quick Version.
  93. These Upgrades Estimate?
  94. E-brake removal
  95. 89 toyota body on 88 toyota frame/engine
  96. Any more breathers found on truck?
  97. timing belt idler pulley
  98. heres a nice laugh
  99. 86 pickup oil in coolant but no coolant in oil
  100. Damage to my CVs with ADD??
  101. Clutch hose connection torque?
  102. Towing and my 93 3VZ-E
  103. help with codes + a popped fuse
  104. Head Cylinder Bolt Torque?
  105. muffler direction???
  106. Need help with finding a header and exhaust
  107. Grille... OEM or Aftermarket?
  108. 86 4Runner playin games
  109. CB vs. Blower
  110. 90 4runner..need torque for axle end bolt & Q?of inner differential hub.pics included
  111. 2nd gen c.b. install
  112. Stock shocks with 2" OME/Downey Leafs
  113. Speedo issue
  114. Need help with bizarre electical short!
  115. I want to do a manual tranny swap...
  116. 3.0 Radiator Installation...kinda lost
  117. radiator support assembly?
  118. drilling into canopea
  119. Reconditioning Old Plastic
  120. Child Seats in a Gen1 4Runner
  121. T-Bar crank?
  122. Motorcrate Engine Sales?
  123. Finally installed the tire carrier
  124. fuel pump help need a part name/number
  125. 89 truck exhaust/cat
  126. my '92 V6 has a mind of it's own...seems electrical prob?
  127. Easy lifting for 94 runner
  128. Help!!! SWAY BAR END LINK...
  129. Lift
  130. Wow, 2951 pounds
  131. 35s on a 89
  132. 84 4R Shifts Too Soon
  133. 2nd gen. Runner MPG/gas filter replacement
  134. Toyota - Let A Diabolical Combination
  135. e-locker ?
  136. Dexron ATF
  137. Clutch? Help???
  138. More A/C crap...
  139. Wanted : 86 4Runner Parts
  140. clutch plate
  141. Steering Problems
  142. Distributor removed: re-time engine?
  143. Timing Vent
  144. 93 4Runner 22RE ????
  145. O2 sensor fixed
  146. Can I recharge my original AC myself
  147. no midrange power, on 22re need help please
  148. '89 3.0 TPS part number problems
  149. Maybe I'm stupid.
  150. AT/TC question
  151. truck wont come out of park!
  152. Front Adjustment Bolt HELP!
  153. SO i got new tires....
  154. Rear Disc Brake Conversion - Writeup
  155. What Tires for Stock 87 Runner?
  156. how much is this gonna cost me?
  157. stock 22re port flow?
  158. Woohoo lift is done, Yay!!
  159. Clean injectors?? - You ain't gonna believe this...
  160. 92 4Runner... just got it back on the road and have a couple new problems
  161. 86 pickup lift help.
  162. timing chain
  163. Gave the truck a trim job Today..
  164. Beefier Tcase mount?
  165. Bent Valance
  166. Turbo 4Runner oil filter
  167. Transmission
  168. Can I bypass my Smog Pump?
  169. head gasket?
  170. Finally got to drive my truck!!!
  171. HIGH OUTPUT ALTERNATOR, any problem if runin too high voltage??
  172. key will not come out....
  173. OEM Plug Wires and Coil question...
  174. Radiator size- 88 4x4 with a chevy 350
  175. Flexing a 95 runner?
  176. Front wheels not turning in 4wd
  177. Pinion Nut
  178. testing the non-heated O2 sensor...
  179. SKID PLATE under engine bay
  180. 3.0 Engine Question?
  181. new bed for 2nd gen...
  182. Transmission
  183. CB antenna opinions
  184. Disc brakes done... question on LP valve
  185. Something CRAZY to look out for..
  186. Something CRAZY to look out for..
  187. Fuel Pressure Regulator
  188. New rims and tires installed.
  189. Wierd Steering Problem
  190. engine swap/newbie
  191. T-Case Gears
  192. un painting rims 94 toyota pickup
  193. Found a Killer deal - Fram AirHog High Flow Air Filter for $4.49
  194. Lost of smooth Idle/bottom end torque
  195. Power issue...
  196. New clutch engages RIGHT off the floor
  197. Dash panel swap?
  198. Junkyard Talk
  199. exhaust manifold sealer?
  200. Best clutch kit for the money and longevity
  201. What shocks should I use with minor lift on '91?
  202. No low beam lights on my '93 4Runner!!!
  203. Need details on the resonator box...
  204. n-fab prerunner type bar?
  205. Intake Application
  206. Easiest way to replace 22RE timing chain damper?
  207. 4X4 A340H AUTO Transmission
  208. Bov
  209. Great, another code 52 thread!!
  210. HG job done now the truck wont idle
  211. Toyota Central America 4WD Tour info needed
  212. Photoshop help
  213. Larger Fuel Injectors... what's compatable?
  214. A/C PROBLEM, Please HELP. I need to fix fast.
  215. "14P" plug on cpu What does it control?
  216. 7MGE swap questions...
  217. Backing plates...
  218. Exhaust Work aaarg
  219. HG/Valve job - now it won't start
  220. 3vze cam bearings seizing?
  221. 1986 Toyota SAS Questions
  222. Diameter of stock roll bar
  223. Shifting To 4wd
  224. are my brake shoes wearing properly???
  225. Alternate Tail Lights - 1994 4Runner
  226. Yotatech's nicest pickup 2 gen?
  227. loss of power after new timming belt
  228. loss of power after new timming belt
  229. SAS Problem/Question!!!
  230. Ring gear size????
  231. Stripes!
  232. Cap Rotor and Wires
  233. Exhaust configuration?
  234. 4WD Problem & Unbelievable Fix
  235. CV Axle Angle?
  236. Bomz intake
  237. shuddering while braking
  238. CB mount
  239. 89 4Runner with a strange overheating issues
  240. Help with spring install
  241. another EGR question.
  242. Retrofitting A/c on a 91 4runner
  243. Help!! 3.0 overheating
  244. Help removing the chunk
  245. Exhaust Pipes
  246. Slow seat belt retractors? This may help you.
  247. Slow seat belt retractors? This may help you.
  248. Small exhaust pipes?
  249. Slow or no return on seatbelts
  250. 22RE Idle Surge
