Front Adjustment Bolt HELP!
Old Aug 3, 2007 | 07:01 AM
Belize Off Road Team's Avatar
Exclamation Front Adjustment Bolt HELP!
i cant find it, can someone please help me find it, the reason i want to adjust it is because i feel that my bump stops are to low, i am hitting them where i really shouldn't be. so can someone tell me where to find t and how much i should adjust it, i have a 1 inch lift in the rear and stock height in the front. with 31 inch tires, soon going to 32 inch. maybe post a pic of where it is would help out too. thanks in advance.
Old Aug 3, 2007 | 07:02 AM
04 Rocko Taco's Avatar
I'm assuming this is on the rig in your sig?
Old Aug 3, 2007 | 07:05 AM
yes my 91 Surf 4WD
Old Aug 3, 2007 | 08:09 AM
ewong's Avatar
http://toyota.off-road.com/toyota/ar....jsp?id=398514
Old Aug 3, 2007 | 08:22 AM
MMA_Alex's Avatar
you're looking for the torsion bar adjustment bolts?
Old Aug 3, 2007 | 08:24 AM
yes i am, and thanks for the link, im gonna go and see if i can see it now!
Old Aug 3, 2007 | 08:27 AM
i put it at 14.5" from top of the rim to fender lip, im gonna go set the bars now to see if there is any difference
Old Aug 3, 2007 | 08:37 AM
ewong's Avatar
Out here where they put salt on the roads in the winter - the bolts are usually NON ADJUSTABLE and need to be cut off after 1 winter....
Old Aug 3, 2007 | 09:03 AM
WOW, thats crazy, it was not that bad, i had some help from an industria strengh WD40 type liquid and it worked really well, there was nothin wrong with the bolt or nut.
Old Aug 3, 2007 | 09:19 AM
keithguts's Avatar
Well don't stop there and leave us all hanging, Did it give you any lift at all?
Sep 4, 2015 09:27 AM
redghost.308
California SoCal
Jul 16, 2015 07:46 AM
razorman8669
Jul 12, 2015 12:13 PM
garagespace
Jul 9, 2015 08:37 AM
