AT/TC question
Old Aug 3, 2007 | 09:06 AM
AndyL's Avatar
AT/TC question
Hey folks,
88 4runner, with an automagic...
Pulled my rear driveshaft earlier this week to have some work done on it - locked the hubs tossed her in 4hi and been driving as a front wheel drive. Then I found an issue I'm not fond of - once engine is turned off, transfercase seems to slip into 2hi - result is vehicle trying to roll away.
Not too fond of this situation - explains a few slides while parked on the trail... E-brake of course is siezed, gotta deal with that, but still not comfortable with the lack of maintaining 4wd within the tcase.
Is this a design thing? Part(s) failure? Is there a swap or fix I can do to eliminate this? (Manual swap is out - permanently buggered left knee; as much as I love em, can't drive em anymore)
Thanks in advance,
Andy
Old Aug 3, 2007 | 09:31 AM
GSGALLANT's Avatar
If your Tranny/Transfer is the A340H, then that's normal. The transfer case is hydraulically controlled. When you shutdown the engine, you lose fluid pressure, so you lose 4WD.
Old Aug 3, 2007 | 09:36 AM
AndyL's Avatar
Would any of the other toyota tcases bolt up, and eliminate the problem?
Old Aug 3, 2007 | 09:47 AM
InternetRoadkill's Avatar
The transfer case on the A340H is married to the main transmission. I have heard of kits that will allow a swap to a manual transfer case, but from my understanding, it's not an easy thing to do.
lectric80
Aug 11, 2015 12:02 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
