Cap Rotor and Wires
Cap Rotor and Wires
Ok to make sure its not the cap rotor or the wires causing my stuttering problem that i talked about on a different post i am going to replace them a quick call to pepboys and i found out that the cap rotor and wires would run me about 50 bucks all together and the brand name is BWD I believe
I just want to know if i am setting my self up for headaches going with these (seemed really cheap to me) or should i be ok?
Yes, you are. OEM ignition components are far superior to their aftermarket counterparts. Definitely spend the extra $ and get yourself toyota parts. If you will be replacing the plugs while you are at it, go with either NGK or Denso. Avoid Bosch like the plague.
Listen to the Chicken. I did after-market last year and noticed that after fording all the flood water, my '95 developed a stutter. Still has it when it gets damp out. I never had any trouble with water with Toyota parts (nearly 20 years of them).
montanatruck
02-26-2017 07:07 AM
