Turbo 4Runner oil filter
too many numbers to figure out. Does the 4cyl 22ret turbo use a special oil filter ????? I thought all 4Runners used the same oil filter
Since no seems to be able to answer...including me..you might try going to a local auto store and selecting a non-turbo and a turbo filter for comparison.
I believe they are the same, not 100% sure - check as directed above at the auto store.
The turbo motor simply has a cooling mechanism that screw on to the standard block oil filter port... I'm using a 22RE filter on a 22RTE block, after removing the oil cooler.
BTW, the Turbo and Non-turbo trucks use the exact same filter. In fact, all 22R, 20R, 22RE, 22RTE, 3VZ, and 5VZ engines use the same filter.
Toyota Mechanical Catalog
Item Number 90915YZZD1
90915YZZD1
Maintenance & lubrication - Engine service - Filters - Oil filter
Oil filter, pick-up, 4-runner, gas 1984
90915YZZD1
Oil filter, pick-up, 4-runner, gas, w/o turbo 1985 - 1990
90915YZZD1
Oil filter, pick-up, 4-runner, gas, w/turbo 1985 - 1988
90915YZZD1
Oil filter, tacoma, 2.7l 2005 - 2006
90915YZZD1
Oil filter, pick-up 1995
90915YZZD1
Oil filter, 4-runner 1995 - 2002
90915YZZD1
Oil filter, t100 1995 - 1998
90915YZZD1
Oil filter, tacoma 1995 - 2004
90915YZZD1
Oil filter, tundra, sequoia, 3.4l 2000 - 2004
90915YZZD1
Oil filter, sienna 2004 - 2006
90915YZZD1
Oil filter, all models 1984 - 1992
90915YZZD1
Oil filter, pick-up 1991 - 1994
90915YZZD1
Oil filter, 4-runner 1991 - 1994
90915YZZD1
Oil filter, t100 1993 - 1994
90915YZZD1
Oil filter, highlander, 3.0l, 3.3l 2001 - 2006
90915YZZD1
Oil filter, highlander hybrid 2006
90915YZZD1
90915YZZD1
90915YZZD1
90915YZZD1
90915YZZD1
90915YZZD1
90915YZZD1
90915YZZD1
90915YZZD1
90915YZZD1
90915YZZD1
90915YZZD1
90915YZZD1
90915YZZD1
90915YZZD1
90915YZZD1
The filter I have in front of me right now says, and I quote:
ENGINE APPLICATION
-1G series
-VZ series
-22R series (JPN., EUR., USA., CANADA)
-JZ series
-M Series
-3S-GTE (Celica ST 165 only)
-2TZ-FE
Part# 08922-02011 (old part number, I have some old filter stock)
so YES the turbo filter is the same as the NON turbo. Sheesh.
That's interesting. The filter on my 3.0 is smaller than the one on my 22RE. I go to the parts store and the small one is what they give me. Different number and all.
I know in the past I had used the same filters on my 99 v6 and my 86 turbo. I just wanted to be sure it was the right thing to do. thank you one and all !
If you into experimenting with filters - I think the 20R/22R blocks used a "ford" sized fitting (aka center threads and O ring diameter)
Its helpful to know when getting a remote filter adapter
(when ya want one that DOESNT use the universal thread adapter thingie and uses PORT connectors not PIPE thread
Well, that would be incorrect. Call the dealer, or, hell, look at the filter box.
ENGINE APPLICATION
-1G series
-VZ series
-JZ series
-M Series
-2TZ-FE
ENGINE APPLICATION
-1G series
-VZ series
-JZ series
-M Series
-2TZ-FE
lots of guys on the 3rd gen. 4Runner forum run the oversized Napa gold 1516 filter. will it fit for your application?
do a search over there you can see alot of good feedbacks on that filter.
