drilling into canopea
Old Aug 4, 2007 | 03:00 PM
premirrider's Avatar
sorry about the spelling of canopea but I was wondering if drilling into it would damage the fiber glass. Is there any special instuctions I need to follow?
Old Aug 4, 2007 | 03:04 PM
bob200587's Avatar
If you have a 94 toyota 4runner your top and roof should be metal....first gens 84-89 had fiberglass tops.
If it's a truck, well then if your topper is fiberglass then ok....You should be able to drill into it, I'd be careful though.
Old Aug 4, 2007 | 03:05 PM
4Crawler's Avatar
Not sure what canopy you are referring to. If this is a 1st gen 4Runner, then I drilled mine to install a rear wind deflector. I used "well nuts" in blind holes for attachment. They are an expanding anchor with a rubber coating and seem to work well on the thick glass fiber shell. If a thinner shell/canopy, use a through-bolt and backing washer.
Old Aug 4, 2007 | 03:11 PM
Im sorry its my pick up canopy. Im not blind drilling, I can get to the other side to attach the nut to the bolt. I dont want to crack the fiberglass by drilling into it I guess that is my question.
Old Aug 4, 2007 | 03:16 PM
ewong's Avatar
If the glass is well made - its fine.
If yer anal - Id radius the hole a tad and seal it with some GE Silicone II before the bolt and washers get inserted.
What are you bolting too the canopy?
Old Aug 5, 2007 | 04:22 PM
I was going to bolt my new c/b antenna ball mount to it, decided to make a little bracket to fit between my canopy and the bed rail.
Old Aug 5, 2007 | 04:26 PM
4Crawler's Avatar
That will be a better setup all around:
- http://www.4crawler.com/4x4/CheapTri....shtml#Antenna
You generally want the antenna in close proximity to the body sheet metal.
some drunk guy
Aug 3, 2021 06:09 PM
wberry85
Apr 6, 2018 08:45 AM
Lons81
Nov 23, 2015 09:25 AM
mdh
Sep 15, 2015 12:12 AM
toyotafreak98
Sep 10, 2015 02:57 PM
