T-Bar crank?
Old Aug 4, 2007 | 01:33 PM
86blue4runner's Avatar
T-Bar crank?
hey yall, does any one know how much i can crank the t-bars on my 4runner? also what are some good after market t-bars, if i get some after market ones, will i be able to crank them any more?
thanks for any help
Old Aug 4, 2007 | 02:00 PM
ewong's Avatar
http://toyota.off-road.com/toyota/ar....jsp?id=398514
Old Aug 4, 2007 | 03:03 PM
bob200587's Avatar
If you're just adding a leaf in the rear you shouldn't need to crank the T-bars. When you do it it will look a little nose down, but you have to remember that the front fenders are cut higher than the rear. Also, the rear springs will settle a little as well.
As far as aftermarket torsion bars, Old man Emu makes some i think.
I've been considering getting them to help hold the extra weight that my bull bar and eventually my winch add to the front end.
Old Aug 4, 2007 | 03:12 PM
ewong's Avatar
about 1.5" of lift
You can get 2" topped out on the snubbers.
It will ride like a brick because it will have ZERO travel
After market bars are STIFFER.
(aka higher spring rate)
They do NOT Allow more lift.
They allow more weight on the front w/o sagging.
SAW makes some
Rancho does too
SAW used to make a two stage one.
There are 300M ones avail too - dont get those unless you know WHY one would want 300M torsions...
NO NO NO NO NO NO NO
Old Aug 4, 2007 | 04:12 PM
rollem's Avatar
If you crank it up too much you'll need a kidney belt.. Downey makes some aswell.
Old Aug 5, 2007 | 05:06 PM
dirtoyboy's Avatar
i had the downey ones and was always happy with them
JonG85
Jan 18, 2023 04:31 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
puddlepirate
Sep 29, 2015 08:02 PM
Shagool22
Sep 28, 2015 07:53 PM
gentry
Sep 28, 2015 06:16 AM
