New Here
Old Aug 7, 2007 | 11:03 PM
FlagSStaff's Avatar
New Here
Hi all! I'm new around here... was referred by a friend of mine. I have an '86 shortbed 4x4 22r. It's all stock except for the wheels. I want to start building it up... body and suspension lift, etc, so any advice or suggerstions would be awesome! Thanks!
Here's a vid:
http://www.booost.com/forums/gallery...g_2007_028.avi
Some pics:
Old Aug 8, 2007 | 12:19 AM
Elton's Avatar
welcome to yotatech.... sweet truck
Old Aug 8, 2007 | 06:10 PM
87TurboYota's Avatar
I'd love to have my truck in some fresh snow like that. Looks like an awesome truck and by the looks of the pictures it's already been a lot of fun. Maybe try putting some herculiner across the bottom of it(just a thought).
Old Aug 8, 2007 | 06:19 PM
jcfb's Avatar
Sweet! I love the snow! I can't wait 'til winter when I get to drive around in some powder
Don't body lift it man!!!
Old Aug 8, 2007 | 06:22 PM
mr toytech's Avatar
sweet truck. and i say do what ever makes you happy.
Old Aug 8, 2007 | 08:43 PM
toyotatom93's Avatar
Welcome and sweet truck.
Things I want to do with my stock truck is replace the springs, expecially the back, there supposed to be one inch higher then the front and mine sag. Plus it would be nice to get some good shocks too. Then I'll also want some 33's.
Also winch bumper with lights, and a roll cage.
But first I gotta do a bit of stuff to the engine and CV joint (Maybe) to make sure I wont be stranded on some desolate logging road or something.
Old Aug 8, 2007 | 08:50 PM
RedRunner_87's Avatar
Welcome to the boards! Makes me miss my 1st Gen even more!
Old Aug 8, 2007 | 09:26 PM
Lysmachia's Avatar
Love the snow.. Love the mud... Love the AZ pines.. Love the truck! Welcome to YT!
Old Aug 10, 2007 | 05:26 PM
FlagSStaff's Avatar
Thanks all! So is the general consensus against body lift? If so, why? I've actually pondered doing a suspension lift so I can go larger on the tires. Thanks again!
Old Aug 10, 2007 | 06:25 PM
jcfb's Avatar
Body lifts only lift the body up off the frame. You can run a larger tire, but you only get the advantage of a larger tire. There's no other point to the body lift. Also, you get that nasty "frame hanging out" look if you go much larger than about 1". If you only want a larger tire, you can shave and hammer the inner fender well and run quite a bit larger tire.
Old Aug 11, 2007 | 04:06 AM
ovrrdrive's Avatar
I have news for you, a bracket lift does exactly the same thing and also gives you the benefit of weakening the suspension. Unless you're doing a full SAS the only benefit to any type of lift is that it lets you run bigger tires.
You can do bj spacers in the front and longer shackles in the back and pick up a little more wheel travel with very few consequences, but if you're looking for substantial lift without cutting and welding, a body lift is a really cheap, safe way to go. And if you put a nerf or a slider on the truck the frame doesn't look bad at all.
Old Aug 11, 2007 | 05:34 AM
thook's Avatar
No one has mentioned it, so I suppose I will.
If you go as large as a 33" tire and larger, without regearing, you'll lose power and mileage. Anything 33" and below won't necessarily require any lifting for clearance.
However, as far as lifting is concerned, and from what I gather, a suspension lift will give you more clearance under the carriage....namely the t-case crossmember and fuel tank. A body lift, other than clearing for tires, seems to give an advantage as far as maintanence....being able to reach certain parts and repair or replace easier. BUT, you will possibly have to make some modifications seeing as how the motor will then be dropping a bit lower in the engine bay....heater hoses, radiator hoses, and some electrical cables. The larger tires will help you clear the differentials, though.
Just to clear tires, any lift is as good as any if you don't go to far....and you really shouldn't need much. I can't see any more than an inch or two.
Personally, I'm not one for bangin' on the truck for clearance.
Old Aug 11, 2007 | 07:31 AM
jcfb's Avatar
Well, good point!
I hate nerf bars too, so I guess I'm just completely anti-body-lift.
Old Aug 11, 2007 | 10:52 PM
sh0kk86's Avatar
Im at the same stage with my truck as you are.
except you prolly have 31's with better rims xD
cant wait to get a weekend off work and drive up north and go wheelin with some friends. where are the pics taken at?
Old Aug 23, 2007 | 05:35 PM
FlagSStaff's Avatar
My truck looked JUST like that when I had the factory wheels and tires... lol
I took the pics at various places around Flag that I've been.
