exhaust manifold sealer?
Old Jul 31, 2007 | 02:56 AM
RustBucket's Avatar
Hey guys,
My 4Runner had an annoying little exhaust leak, so I decided to fix it the other day. Found another manifold, cleaned it, had it planed, fixed/helicoiled the studs in the head, got a new gasket and flange gasket donuts, and bolted it all down. Still leaked, but it was a completely different tone. Just a side note I was torqueing down the 14mm nuts from the center out with very gradually increasing torque (probably 5 or 6 runs, finishing at maybe 35 ft-lb or torque)
So yesterday I tried it again, reused the old gasket (had only driven like 10 miles with it) and it's the same story. The surface of the head may very well be a little warped and maybe that's why I'm having no luck.
For a final try here's my idea: take it all off again, get a NEW gasket and NEW flange gaskets and coat the gasket on either side with some sort of high-temp sealant like Ultra Copper Permatex.
I'd like to get some opinions on this project...
Old Jul 31, 2007 | 04:09 AM
Elton's Avatar
maybe try these gaskets ? http://www.remflex.com/
Old Jul 31, 2007 | 04:18 AM
04 Rocko Taco's Avatar
I assume machining heads is beyond the realm of 'what I want to do right now'?
Old Jul 31, 2007 | 04:27 AM
scrid's Avatar
manifold leak
I seriously doubt any sealer, even the Permatex will hold up to the heat and pressure. If resurfacing the head surface isn't an option right now, on a budget I would be tempted to possibly used two gaskets and double them up.
Old Jul 31, 2007 | 04:29 AM
and have you gona after it with the wetstone trick, granted if its leaking its probably more than you'd ever get like that, but worth a shot, for the effort, course thats probably harder to do in the truck. lol.
Old Jul 31, 2007 | 04:39 AM
scrid's Avatar
manifold leak
Also worth a try 04 Rocko Taco, good thought.
Old Jul 31, 2007 | 04:47 AM
Come on, its oh so easy out of the truck... lol.
i know, just yank your motor out of there, and we'll tear into it when i come up...
EDIT: I know I know, nitrile gloves and bare feet, only in the south. lol.
Old Jul 31, 2007 | 06:17 AM
if all else fails man, here is a good consition 22R head for sale. (guy also has another head that needs rebuilding, and a block, also)
https://www.yotatech.com/forums/f107...r-head-120566/
Old Jul 31, 2007 | 07:52 AM
89-4Runner's Avatar
I used that permatex ultra copper on my downey headers and it held up fine. when I took the headers off two years later when I parted out the truck the permatex was still in excellent shape, actually still holding the headers on tight after i took the bolts out. the permatex wasn't dried out or burnt, still could peel it off (rubbery...)
Old Jul 31, 2007 | 08:25 AM
thook's Avatar
I hate to be the one to tell you this, but your gloves......uh, they don't match.
And just to note, "professional" southern men wear nitrile socks.
Old Jul 31, 2007 | 08:38 AM
Ringmaster's Avatar
I was gonna say, whenever I see peeps wearing exam gloves,
Run Forest Run!
Old Jul 31, 2007 | 10:39 AM
PirateFins's Avatar
I just used the Ultra Copper Permatex on my header that was leaking like you wouldn't believe. So far it has been 2 weeks and all is quiet. I put a layer on the head, then gasket (toyota), another layer and finally the header. I also used it on the 3 EGR tube connections.
Old Jul 31, 2007 | 03:43 PM
RustBucket's Avatar
Sweet! Well I'll try that stuff then!
Dude, Chris, what are you doing in MY driveway dressed like THAT? And isn't that one of MY engines?!
Zach_trun
Jan 22, 2020 04:42 PM
Streetrod19772000
Sep 10, 2015 06:22 PM
Obmi
Sep 10, 2015 03:36 AM
idadan208
Sep 7, 2015 09:06 AM
