- loss of power steering in low rpm's
- vin plate thread
- battery/alternator issues
- Should I Do A Tranny Flush?
- rpm pulse
- catalytic converter melted
- lack of power
- Did I bend a valve???
- Steering Box Fitment
- Intermittent rough idle
- ISR done. Is this ok?
- Head gasket recall information
- 3vze valve tapping/tick or rod knock... ?
- Upgrading to Larger Tires - Spare Tire Concern
- Are New Toyota Trucks as Tough as Our 89-95's?
- pistons hitting
- 86 4runner 38s and autotranny
- motor bogs while driving
- 94 toyota pickup
- Engine build Q's
- Shock bushing missing. Options?
- block pitting - how much trouble am I in?
- 22R-E iddle
- O2 sensor
- Toyota 4Runner Passenger Door
- Im doing a Head and Timing Chain cover/etc job, and I have a quick question
- V6 transmission and transfer case
- HELP No Defrost!?!? Plugged vents?
- Leaf Spring Compatibility
- Fiberglass Front Fenders thread again!!!
- no NE signal at ECU
- front windshield is leaking???
- Front Wipers not working
- gauge cluster conversion help
- what tranny do i have?
- Timing mark jumps. Suspect distributor. Any advice?
- Tire size for best MPG all city driving
- writeup for timing chain cover removal
- Dual t-case shifter options?
- timing chain guides
- ebay timing set??
- Thorley Headers Install Questions
- ? headliner removal '92 xtracab
- Engine has no power
- Solid Axle Pitman arm play/knock
- Tachometer acting wierd
- 2 or 3 row radiator?
- Help! 3.0 with intake issues
- Think this is my rear main seal leaking? pics
- Another 3rd Member destroyed......
- cant get head gasket to seal at timing chain cover
- PIC REQUEST: Sequoia Rims on 4runner
- Catalytic converter
- 22RE timing chain cover gasket leaking
- Need help 22re problem
- Loose/swerving steering on road
- Still having coolant issues.
- power chip
- stuck without a clue
- WHat side of radiator trans fluid come out ?
- Rebuilt Engine
- Altrom parts any good?
- Best parts to swap from 4runner into pickup?
- Cab Swap
- Engine replacement
- Trouble shifting into gear
- best fuel filter?
- Are my rotors correct/usable?
- Torsion nut stuck!
- New to me truck pulls to the right.
- Fuel Pump
- 4 cylnder Detroit locker question? How does it work?
- New stinger/winch bumper on truck. pictures inside
- Piston slap after top end + chain job 22re
- coolant leak/transmission cooler question
- 86 4runner odd brake issue
- shift into reverse, parking/dash lights come on?
- Temperature gauge problem
- failed smog high HC
- 87 Runner Speed Sensor
- Coolant Leak
- a/c and stalling
- 91 runner 3.0 acting up
- cracked timing cover
- Market for 2nd gen 4runner bumpers?
- Brake Issue, running out of ideas...
- 2nd Gen Options list?
- Fuel pump
- What skid plate is this?
- 93 3vze started and ran then nothing. Fuel issue
- Help!! 1995 runner Tcase and question on issue with tow on a dolly
- compression issues
- Could use some advice on a used 5spd
- 3.0 Valve Shim O.D.?
- 1986 4runner body work
- question about shackles
- auto tranny acting weird
- Front Main Seal
- 91 runner fuel pump? or what?
- swapping newer 3.0 motor in older 3.0 vehicle
- A Routine Head Shave? Really?
- Fan Clutch?
- Not Just Another 22re Misfiring thread
- looking for 86 toyota pickup bed 4x4 6" bed
- M.A.F sensor
- Torsion Bar adjuster bolt confusion
- 4WD Help!!
- Spare tire mount, 89 4runner
- Part number location on manual 1986 tranny...
- 4Runner rollbar in Extra Cab?
- Locker wont Slip!!!
- 92 reg Cab 4x4 pickup belt squeel
- thinking of lifting my 92 extd cab
- Water pump holes/My super clean valvetrain
- 4.56 gears from '93 in an '87 with 4.30
- Fuel System Cleaner?
- 1989 22re vacuum lines
- Question re: Timing belt-Hydraulic Tensioner 3.0
- 22re clutch fan wont shut off
- Ignition timing
- 94 P/U 22re will not start cold. Replaced so many parts
- Help with a 1992 toyota pick up 22R-E 4x4
- battery light and brake indicator
- Bed help
- Code 25/26 problems... 22RE
- Tacoma 16" wheels on my '93 Pickup :)
- 1986 alloy sizes
- 22RE Running bad
- spun a rod bearing bad/good
- oil leak@drums
- electrical issue with brake lights
- over complicated rear brake system
- Time to rebuild
- 3.0 slow-no more
- 86 gauge cluster
- Can't set proper timing. PLZ HELP!
- Call/wire diagram 86' 4runner 22RE
- 3.0 vze knock a 2500 rpm
- Idle fluctuation with brake pedal depressed
- 90 pickup jerking and stalled on highway
- noise when 4x4 is engaged
- A341 trans and a340h trans similarities
- Driveline Angles
- Driving with diagnostic codes a bad thing?
- Where to buy stock 4wd fenders????
- Got my DT Tri Y's today !!
- check engine light on & a cough when accelerating
- My engine won't crank over even with a new battery
- Gear confusion on my 93 4runner.
- Writing a Knock Sensor Wire Replacement Guide but I need help
- NEW 22RE engine
- Stiff/Bound front end
- my 95 V6 3.0 gone into limp mode codes 14 and 52
- Fuel Filter Compression Nut Destroyed
- very cold (below 0) sporadic starting problem
- Fuse/Relay questions
- weird coolant leak
- Low shift points. 22re 4wd AT
- 1992 pickup speedometer electric or cable driven?
- 95 4runner 3.0 v6 overheating
- First generation rear window
- vibrations, and random swerving
- Installing a factory Roof Rack?
- 86 toyota 5sped tranny problems
- 95 3vze 4x4 MT Pickup no start up after OT until 20 minutes later...any ideas?
- TPS question
- 86 22re no "check engine" light
- possible fuel pump and other problems
- Does a twin stick tcase work without the twin stick?
- 2nd gen power mirrors broken
- 91 5 Speed Speedo Drive Gear Retainer?!?!?!
- 91 pickup coolant sensor location?
- Finally dug into my rear axle project today...
- Shot front IFS CV's: Non-performance question
- Wiring Diagram for Cab light in 87 4runner
- Injector question
- Blown Head Gasket
- metalic rubbing sound
- Another blown 3VZE head gasket
- Just cranking
- emission help
- Trans. stopped w/o any symptoms??
- truck is making my eyes and throat hurt
- Valve job pleasantries
- Adjusted Valves Now wont run
- what kind of noise would it make with no pilot bearing in the back of the crank
- Which injectors do I have?
- Part# for 1986 auto transfer case same as manual?
- I am trying to find an intake and a carb for my 22R
- speedo/odometer still inop
- 1991 PU Tailpipe Vibrates Against Body
- Will the intake manifold off of a 20r fit on a 22r?
- Fuel Injector Gasket Kit
- anyone know where this goes? PICS!!
- Specific scenario question, 33's on 22re/stock gear..."Is it REALLY that bad?"
- 1.8" bj spacers dont fit
- flowmaster super 44 on a 3.0
- Motor building a lot of vaccum pressure! help
- no slight vacuum on egr cose 71
- Thorley THY 555 y-c headers
- Trail Gear creeper U joints?
- Radiator Issues
- Vibration 93 hilux surf
- 93 toyota pickup 4x4 grille guard search!
- is my headgasket blown?? help..
- Seat Covers for 93 P/U Xcab DLX
- results from compression and leak-down test
- '94 P'up fuel line leak. Need help finding parts.
- 1986 22re metalic ticking?
- 91 4Runner 3.0L Rough Idle concern with a "catch"
- project dual-fuel is a go
- Recovering My Center Console Arm Rest (LOTS O' PICS)
- Digital Dash Problem
- prerunner
- How to Crank Torsion bars?
- strange idle problem on rebuild 22re
- Console hinges!?
- 22re wont start after timing component replacement
- Going to look at used engine...advice/tips please.
- 94 22re 4x4-noise under pass side floor
- Brakes slip and clunk then fine???
- Looks like my engine temp sensor?
- Head Gasket after all?
- Water temp sender in top hose
- 2L-TE diesel questions
- thoughts on ECM relocation . . .
- Lower End Rebuild
- I need help with my 84 Yota that has a 92 22R-E engine.
- 1993 Pickup 22re > Works great, 3 hours later, very poor?
- 86 22r help no power
- No power to fuel pump
- Toyota pickup lingo
- O/D relay help
- 22re with 22rte turbo kit?
- 90 4 runner 22re doesnt idle
- Best way to test a radiator?
- BOV on 86 22ret with ct20?
- 4.56 gears: Fun With My Rear End
- Coolant System Leak? Among other issues...
- aftermarket temp gague
- Blower Motor weak Air flow
- 80 amp alternator fuse
- Transfercase leak.
- what goes here?
- 88/89 3.0 vaccum routing
- radiator leak/high idle and surge
- hydrocarbons at 41.26 wth
- 22re Severe Oil Leak and Extremely Poor Gas Mileage.
- Rebuilt 22re consuming oil during break-in?
- camshaft bolt hole stripped.
