anyone know where this goes? PICS!!
Old Mar 4, 2011 | 09:08 AM
stephencox's Avatar
Question anyone know where this goes? PICS!! (updated)
was workin on the truck the other day and got under it to drain the coolant and found this little guy hangin down. looked around and couldnt figure out where it went. sorry for the crappy pics, but any ideas? it runs along that bottom crossmember the skidplate bolts to
Old Mar 4, 2011 | 09:14 AM
xxxtreme22r's Avatar
your washer fluid work?
Old Mar 4, 2011 | 09:35 AM
RustBucket's Avatar
Oh crap! That goes to your turbo encabulator!
Old Mar 4, 2011 | 09:52 AM
stephencox's Avatar
yeah still works
hahaha, hold on, maybe i should go check the alignment on my rotary girder. i think the flux capacitor overheated and threw it out of wack
Old Mar 4, 2011 | 10:12 AM
RustBucket's Avatar
Better check your drawn reciprocating dingle arm while you're at it.
http://www.youtube.com/watch?v=rLDgQg6bq7o
justin_4runner's Avatar
4wd still working? looks like the wire that goes from the actuator for the light on the 4wd.
Old Mar 4, 2011 | 11:52 AM
Stuwy123's Avatar
+1 on 4wd indicator.
There's a little plug right behind the front crossmember where the diff mounts.
I'm sure it's covered with gunk and mud, take the pressure washer to the front mount, and you'll see it.
Old Mar 4, 2011 | 12:15 PM
stephencox's Avatar
cool, 4wd light hasnt been coming on, ill check it out, thnx guys.
Old Mar 4, 2011 | 07:45 PM
iamsuperbleeder's Avatar
yeah that's on the other side of the engine bay
Old Mar 5, 2011 | 04:53 AM
1993hiluxsr5's Avatar
Yes that plug is off one of your sensors for 4wd, without it plugged in your 4wd won't engage, it's off 1 of 2 sensors located on the front diff, not hard to find, one on the front or the one on the back, it's for your ADD diff so it's pretty important.
Old Mar 8, 2011 | 01:38 PM
stephencox's Avatar
alright, got underneath it again and i still cant seem to find where the plug goes. i see the one end goes straight into the diff, but no idea where the other end hanging down goes to. does anyone know at least what to call it so i can search the internet?
Old Mar 8, 2011 | 02:16 PM
vital22re's Avatar
totally a bro
it plugs into the main engine harness on the driver front corner. by the oil filter if i can recall right.
Old Mar 8, 2011 | 03:18 PM
drmix's Avatar
Yup I believe its actually the last plug on the harness
4.34runner88
Feb 7, 2016 02:24 AM
Obmi
Nov 24, 2015 11:37 AM
bobjohnson2121
Sep 17, 2015 08:07 AM
HiLuxer
Sep 9, 2015 02:43 PM
