Coolant Leak
Old Mar 11, 2011 | 08:33 PM
weaselman's Avatar
Coolant Leak
so my rad cap ONLY does this when the coolant reservoir tank is FULL
but when the coolant reservoir tank is EMPTY i have NO leaks what so ever.
any clues as to why? and the reservoir tube clamp is tight,
Old Mar 11, 2011 | 08:52 PM
justin_4runner's Avatar
does ur tank have a drain spot for when its full? some caps have it where it goes over the tank and drains it on the ground. if not then what it is doing is, the cap is releasing the coolant and with no more room in the tank it is pushing it out where ever it can even if it means where it is.
Old Mar 11, 2011 | 09:12 PM
weaselman's Avatar
the reservoir tank has a drain hose on the cap and its not restricted... and even when the tank was half full it was still doing it. but now the tank is empty, it isnt leaking at all anymore.
Old Mar 11, 2011 | 09:21 PM
something is pushing back in the tube and letting the water push out the cap. how new is that cap? might want to replace or see if there is a seal to make the water go down the tube and not out the top.
Old Mar 11, 2011 | 09:25 PM
weaselman's Avatar
radiator and cap are less than a month old. ill check the tube again for restriction.
Old Mar 12, 2011 | 03:34 AM
peow130's Avatar
Why is that overflow tank full, anyways?
It should only have coolant in it if your truck has gotten too hot...
It doesn't feed into the system at all lol
Old Mar 12, 2011 | 06:17 AM
WHAHAHAJR's Avatar
Bump bump
Old Mar 12, 2011 | 06:30 AM
Jarhead2147's Avatar
I have to agree with peow130, your over flow tank shouldn't be full, unless your motor overheated, or your cap opened prematurely. Even then if the cap is working correctly it should siphon back to the radiator when it cools down.
Old Mar 12, 2011 | 09:17 AM
weaselman's Avatar
I meant that its filled to the "Full" mark that is on the reservoir.
Old Mar 13, 2011 | 03:56 PM
annoyingrob's Avatar
I wasn't aware that it was supposed to be a reservoir.
Old Mar 13, 2011 | 07:09 PM
weaselman's Avatar
Well, it has a mark for full and a mark for add.
Old Mar 15, 2011 | 01:58 PM
Just a silly question but, are you sure that the reservoir doesn't have a hole or crack in it? Just asking.
Old Mar 15, 2011 | 04:00 PM
weaselman's Avatar
im postive there is no hole or crack.
the pictures show it all leaking out of the cap. and my resvoir has been empty for about a week now and havent had a single leak out of the cap or any overheating issues. and the rad is always full when i check it.
Blamalam
Mar 12, 2022 07:34 AM
SubiKing
Aug 21, 2021 03:57 AM
WellsR
12
Jul 31, 2015 03:27 PM
itzmywife's
Jul 25, 2015 04:55 PM
Avenged
Jul 9, 2015 07:55 AM
