no slight vacuum on egr cose 71
Old 03-03-2011, 08:43 PM
willyt4r's Avatar
Not sure what the fault is, while following the FSM it states that I should have a slight vacuum while at 2500 rpm when warm. I do not. I can kill the engine when the vacuum is directly hooked up and all other FSM tests pan out. I have replaced the EGR with a junkyard find - but the test result is the same. 1991 4runner 3.0 code 71 500 miles on a rebuilt longblock vacuum lines are correct.
Thank you in advance for your ideas
Old 03-03-2011, 08:58 PM
justin_4runner's Avatar
u might want to trace the line and see where u are losing the vacuum. i know u have a metal tube that was clogged and had to run a new line for one...
Old 03-04-2011, 06:12 AM
shaunneuhaus95's Avatar
or its a egr transducer thats what was bad on my 3slow
Blamalam
03-12-2022 07:34 AM
Colington
08-13-2015 02:21 PM
e_richard
07-30-2015 06:50 PM
Poppie51
07-23-2015 05:03 PM
Poppie51
07-16-2015 06:16 PM
Quick Reply: no slight vacuum on egr cose 71
