Lower End Rebuild
Old Mar 1, 2011 | 01:22 PM
xtultegra's Avatar
Lower End Rebuild
1990 22re 4wd
In the last year I have replaced complete timing, complete upper end. Now I have a rod bearing making noise so I'm gonna pull the crank and have it ground down and replace all rod and main bearings. Also, I'll be replacing the clutch since I'm already in there and also everything behind the exhaust manifold. I've got 180,000 miles on the truck. It's mainly a work truck and I don't want to spend money on anything I don't have to. Also, I'm in Calif. so I'm heavily restricted on what I can do on the exhaust side.
My question is what suggestions you all might have on what else I should do? Such as pistons, honing etc. Not looking to build a hot rod, just get my girl good and healthy.
Old Mar 1, 2011 | 01:35 PM
spokane.yota.man's Avatar
Well, how far you want to go depends on what you want to spend. If your in there for the bearings it would be worth your while to at least do new rings. Everyone always says to do it right and do it complete. But that means more money of course. I'm doing a rebuild that I was originally going to do cheap with just rings, bearings and that. I found a lot of good info on the flex hone. I decided to just do a full rebuild but people do have success with doing a home hone and just replacing rings, not boring with new pistons and such. If you go the home hone method I'd recommend cast rings, they seal easier. Rock rings and the like have different coatings which make them last longer but harder to seal, esp if its a garage special machine job. Or you could do a full rebuild with machine block, bored over pistons, all new parts, etc. Depends on the time and money you want to spend. Good luck.
Old Mar 2, 2011 | 02:53 PM
xtultegra's Avatar
Thanks
Old Mar 2, 2011 | 05:58 PM
xtultegra's Avatar
Is the overbore on the block worth it?
Old Mar 3, 2011 | 05:35 AM
Re boring is a safer bet. Even if cylinders look good they could still be out of round. The fsm gives specs for checking all that. There are lots of rebuild threads on here that you should read through, it will give good understanding of time and money involved. Also Google ttora fsm and download a manual, its a must have for a rebuild.
Old Mar 3, 2011 | 05:45 AM
Ezrider_92356's Avatar
if your pulling the motor i say fully rebuild the block, if you wanna try to band-aid it try rolling in some new bearings its hit or miss.
Old Mar 3, 2011 | 05:46 AM
before considering a bandaid fix you should check your compresion and see where you stand.
88sasturbotoy
Jan 30, 2026 01:57 PM
young buck
18
Aug 27, 2018 02:40 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
Sep 4, 2015 09:27 AM
calderp
Jul 27, 2015 09:58 AM
