Trouble shifting into gear
Old Mar 12, 2011 | 05:47 PM
Justinmars's Avatar
Help me!
So when I push in my clutch to start my 1990 P/U 4x4 22RE, it starts fine. When I take off in 1st it takes off just fine. When I start to shift in to 2nd, it just won't shift unless I rev up the engine. I shift through the rest of the gears through the short-shift method, which works fine. I cannot down shift, and this problem has just progressively gotten worse. So my question is, where do I start looking for problems? Any info. from anybody would save me "big time". Thanks all in advance!
Old Mar 12, 2011 | 06:58 PM
ROCK LIZARD's Avatar
Don't know where you live but if this occurs only when you first start and the transmission is cold, what you describe is a common problem. I have an '84 4Runner with 5 speed manual 4WD and live in AZ low desert where 40 degrees F is a typical "cold" winter morning and I have difficulty shifting into 2nd gear. Once it warms up the symptom goes away. Just a quirk.
If the symptom occurs even when transmission/air temp is warm, then you have a problem with the syncro. Expect to spend $$ unless you can DIY.
Old Mar 12, 2011 | 07:32 PM
Justinmars's Avatar
I live in Washington State and the problem has just progressively gotten worse. Doesn't matter the temp outside. thanks though I'll look into synchros.
smthwsn357
May 1, 2024 07:28 AM
mskalmus
May 28, 2017 07:51 AM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
Jnkml
Jul 6, 2015 01:20 PM
