Catalytic converter
Old Mar 13, 2011 | 06:23 PM
Quentin27's Avatar
Catalytic converter
I have been getting some bad gas milage and was wondering if replacing the catalytic converter would help. Just had tune up about 2 months ago and had the fuel filter changed in the process. Any ideas? It's a 91 v6 3.0 with 186,000. I also have engine light on. I'm thinking it could be the o2 sensor could that effect the milage?
Old Mar 13, 2011 | 06:27 PM
iamsuperbleeder's Avatar
could be, but I'd put more money on the O2 sensor
search how to check and see why the check engine light is on and see what's causing it
Old Mar 13, 2011 | 06:30 PM
rworegon's Avatar
O2 sensor can affect mileage.
Some interesting info on O2 sensors to consider:
http://www.4x4wire.com/toyota/4Runner/tech/O2_Sensor/
Old Mar 13, 2011 | 07:28 PM
Quentin27's Avatar
Thanks guys. Gonna check it out.
Old Mar 13, 2011 | 09:37 PM
drmix's Avatar
Id check the CEL codes and go from there
Old Mar 13, 2011 | 09:53 PM
Quentin27's Avatar
What is cel? And how do I check it? Do I use the diagnostic scanner? And if so do u know what the best/ cheapest one to get? Don't know a while lot about this kind of stuff. Thanks again for all the help guys.
Old Mar 14, 2011 | 01:17 AM
prorunner's Avatar
You can go you schucks or pretty much any local auto parts store and they should let you use one for free in their parking lot. CEL = Check engine light.
Old Mar 14, 2011 | 09:14 AM
mt_goat's Avatar
He doesn't have OBDII on a 91 truck, all you need is a paper clip to check codes with his truck. http://personal.utulsa.edu/~nathan-b...26diagnosi.pdf
Old Mar 14, 2011 | 09:19 AM
mt_goat's Avatar
I don't know what state you're in but if you can get away with a cheap cat I'd recommend replacing it with a new one. Recycle your old one and collect lots of cash. I was amazed how clogged the small holes were in my old 93 cat when I took it off at 115,000 miles. The new cat I put on was $60 and I got $140 for recycling my old one. Now if you live in CA you're not going to get away with a $60 cat.
kawazx636
Oct 6, 2021 03:03 PM
Longbed 90
Oct 19, 2015 11:05 AM
Cycles
Sep 29, 2015 06:37 AM
Scotttekoch
Sep 28, 2015 10:30 PM
larrys93pickup
Sep 17, 2015 07:05 PM
